jbbtex Senior Member
| Posted: October 26 2008 at 12:57 | IP Logged
Try changing the "+" to a different character like "#", "%" or "*".
__________________ Brady
| Posted: October 26 2008 at 13:29 | IP Logged
From everything I’ve read the VTS should work. Changing the + to # had no change to the results. I even tried VTD to lengthen the tone duration. I wonder if I’m being slammed by the VOIP. I know I can not do standard modem to modem communications like training. The cloud in the middle retranslates everything and doesn’t put it back. Oh well try again tomorrow… Surf is up.
| Posted: October 26 2008 at 20:41 | IP Logged
Tried ATA and it sings at me but the gate still did not open.
| Posted: October 27 2008 at 18:21 | IP Logged
I had a brilliant idea but I’m not very brilliant on how to implement it. I recorded the dual frequency touchpad #5 as a wav file but how do I send it through the plugin? PH_PLAYSOUND will play it but that won’t work across the com port.
| Posted: October 27 2008 at 19:55 | IP Logged
You would need a voice modem to do that, and then you would need to get that file, in the proper format, to your modem.
Off the top of my head, another way would be a serious contraption...
Use a relay to connect/disconnect an old phone placed near a speaker!
| Posted: October 27 2008 at 23:18 | IP Logged
As funny as it may seem, when we had to pass inspection at the gate for 911 we tested with a wav file recorded with sirens and played it in the car at the gate podium. The gate opened and we passed. So much said about security.
