syonker Senior Member
| Posted: February 02 2012 at 17:50 | IP Logged
Ugh. Alright, I put the files from the ZIP in, and when executing PH, I get the following: "This application has failed to start because PBVM115.dll was not found. Re-installing the application may fix this problem."
Thoughts?
-S
><(((º>`·.¸¸.·´¯`·.¸><(((º>¸.
| Posted: February 02 2012 at 21:44 | IP Logged
S,
Be sure and do a full install of version 2.1.2 first (first post of 2.1.2 thread). This will install into c:\powerhome (rather than c:\program files\powerhome) and will preserve your existing setup. After installing 2.1.2, then unzip 2.1.4 over it. You'll then need to copy your pwrhome.db and pwrhome.ini files and do a database upgrade, etc.
moniputer Groupie
| Posted: March 03 2012 at 19:45 | IP Logged
I moved PH to a new server today and I am getting the same
error.
Installed 2.1.2 and PH came up fine. Then copied the 2.1.4
files and now I get the error.
The new server and the old were both WHS 2011 but the new
install is under ESXi 5.0.
Never had this error before.
