bmwragtop Newbie
Online Status: Offline Posts: 27
| Posted: April 19 2009 at 18:09 | IP Logged
Hi All,
I'm working my way through learning how to create a Power-Home plugin using Visual Studio 2008 (C++, using MFC). I am using the skeleton plugin as a simple starting point.
I have managed to get the plugin to behave the same as the pre-packaged skeleton plugin from within the "ActiveX Control Test Container" provided by Microsoft.
However, when I attempt to load my plugin into Power-Home, I am still getting an error with a value of -2 returned.
The plug-in has been registered.
I am not sure where to go from here, as everything seems to be working outside of Power-Home.
I suspect my issue may have to do with the way Strings are passed (type of string and using by reference or by value).
Are there any debug tips people have for debugging the issues when loading a new plug-in into Power-Home?
Tom
| Posted: April 20 2009 at 20:59 | IP Logged
Tom,
I'll look through my server for a .Net version of the PowerHome Skeleton plugin that my wife put together for me. As soon as I find it, I'll put it on the downloads page and post back here.
bmwragtop Newbie
| Posted: April 20 2009 at 21:12 | IP Logged
Hi Dave,
Thanks! That would help.
I'm sure there is just one small thing I'm missing in the configuration that is not playing well with Power-Home.
-Tom
bmwragtop Newbie
| Posted: April 28 2009 at 19:01 | IP Logged
Hi Dave,
Have you had any luck finding the .NET plugin code on your server?
Normally, I would not be in a rush, but I am creating a plugin to webcamXP, and I want to make sure it will work before I buy webcamXP. I have about 3 weeks left on my trial period, and I would like to get the plugin up and running in that period.
Thanks in advance, and thanks for your great support!
-Tom
| Posted: May 02 2009 at 21:17 | IP Logged
Tom,
Sorry to take so long, but Ive found it. Its more or less the PH Skeleton Plugin that has been converted to C# by my wife. You can get it here: http://power-home.com/download/ph_plugin_net.zip
Let me know if you need it in VB.net or another language.
bmwragtop Newbie
| Posted: May 02 2009 at 22:55 | IP Logged
Hi Dave,
Thanks!!! I'm away from home tonight, but I'll download and try it out tomorrow.
No need to apologize, though. You're a busy guy!
-Tom
patrickm Senior Member
| Posted: December 23 2010 at 05:03 | IP Logged
I tried the C# plugin and it would not register as it was in the zip file. I rebuilt the VS2008 project with COM interop checked and it registered successfully in 64 bit Win7.
However the plugin initialization returns an error of -2.
I can't find anything describing the init error codes. Anybody got a plugin working with VS2008?
| Posted: December 23 2010 at 20:54 | IP Logged
The -2 during initialization means that the classname could not be found. This is most likely the result of not properly registering the .net COM object.
After compiling the project in .net, you must run the following command to "register" the COM object and type library:
C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\regasm.exe "C:\your_devel_directory\phplugin_net\bin\release\ph_plugin_ net.dll" /tlb /codebase
See where this gets you and let me know.
| Posted: December 24 2010 at 12:14 | IP Logged
I successfully ran regasm prior to the error without the /tlb /codebase switches.
I ran it again with /tlb and /codebase switches and it generated a warning.
I then reinitialized PH and it generated the same -2 error.
I ran a DLL Viewer and saw that no functions were exported. DOes this DLL work for anyone else on other platforms? I'm trying this on 64bit Win7 Ultimate.
Edited by patrickm - December 26 2010 at 23:58
mertfg Newbie
| Posted: February 03 2011 at 23:32 | IP Logged
I would request bmwragtop to let me know whether he has succeeded in solving the issue related to Power-Home plugin. I am having a similar problem at the moment and I am also seriously thinking of making use of .NET plugin. I hope that bmwragtop will provide information in this regard soon.
__________________ magnetic messenger
Carbin Newbie
| Posted: April 19 2011 at 04:09 | IP Logged
bmwragtop wrote:
Hi All,
point.
iphone4 cases
ipad2 Sleeves
ipad2 Screen Protector
returned.
value).
Tom |
Edited by Carbin - April 19 2011 at 04:12
| Posted: April 19 2011 at 10:06 | IP Logged
I am in the same situation. I can generate and use ActiveX plugins with other applications but I get the same -2 error on PH startup.
billy77 Newbie
| Posted: May 09 2011 at 00:55 | IP Logged
Carbin wrote:
bmwragtop wrote:
Hi All,
point.
iPhone case
returned.
value).
Tom |
configuration that is not playing well with Power-Home. |
yes. it can be a config issue. my fren was able to solve it for me. but i din follow his steps.
