| Posted: October 08 2011 at 12:41 | IP Logged
OK, I’ve got a simple question… I am playing with Control Center and have not found a way to remotely automatically refresh the screen using Web Server. If I change a global in the host via a remote device the change is not reflected until I do a refresh manually. Am I missing something basic here?
| Posted: November 05 2011 at 01:13 | IP Logged
Bump... Any thoughts Dave
| Posted: November 05 2011 at 02:09 | IP Logged
Pete,
If you're speaking about the web based Control Center, then I assume you've got some global variables on a CC tab. If so, then you're correct, there is no automatic refresh and the global will not change until you refresh manually.
However, I do have this on the to do list and plan on implementing a background refresh on a hidden tab for CC changes. I should then be able to use javascript to update the currently displayed web CC without having to do a full screen refresh.
It won't be in the next beta (already bit off way more than I should have :( but we'll see what we can do for the one after.
| Posted: November 05 2011 at 08:35 | IP Logged
I was afraid that is what’s happening. I just wanted to make sure there wasn’t some simple solution I was missing . Thks for the feedback……
