nick7920 Senior Member
| Posted: August 25 2015 at 17:13 | IP Logged
working machine has
cswskax6.ocx
and non working has
cswskax8.ocx
I am going to copy the cswskax6.ocx and test
| Posted: August 25 2015 at 17:44 | IP Logged
Nick,
Sounds good. cswskax6.ocx should be the one (I thought
it was 7 but looks like its actually version 6).
Let me know how it goes.
| Posted: August 25 2015 at 17:51 | IP Logged
by using cswskax6.ocx cant even run
A critical error occurred at 2015-08-25 17:50:49.004.
PowerHome Version: 2.1.5d
Critical Error Count: 1
Error Number: 39
Error Message: Error accessing external object
property autoresolve at line 16 in constructor event
of object uo_socketserver.
Window: uo_socketserver
Object: uo_socketserver
Event: constructor
Line: 16
| Posted: August 25 2015 at 18:01 | IP Logged
Nick,
The error you got isnt related to the plugin and is
coming from the Socket Server within PowerHome (which is
using cswskax8.ocx). Is that file still in your syswow64
directory? If so, try running regsvr32 against it to
make sure its registered properly
| Posted: August 25 2015 at 18:44 | IP Logged
no mine is not 64 bit both are window 7 -32bit
found only one file cswskax8.ocx their is also one
other file which is cswsvax8.ocx does it has to do any
thing .
Nick
| Posted: August 25 2015 at 18:59 | IP Logged
cswsvax8.ocx is another Catalyst control that is used by
PowerHome. All of the cs????ax8.ocx are Catalyst
controls and would have been installed by PH (since
you're 32 bit they'll be c:\windows\system32). I would
go through and run regsvr32 (as an administrator) on
each one and your problem should go away.
| Posted: August 25 2015 at 19:16 | IP Logged
if I unregister cswskax8.ocx and rename the file and
reboot then run PH will get critical error, so does it
mean it is still using it. in windows registry you will
find entries for above file.
Nick
| Posted: August 25 2015 at 19:22 | IP Logged
Nick,
Im not sure I fully understand. cswskax8.ocx (as well
as the other cs????ax8.ocx files) is used throughout
PowerHome in multiple components (the ph_geturl
functions, the webserver, the socket server, version
1.9 and above of the raw socket plugin, etc). You
can't unregister, rename, or delete these files
and have PowerHome still work. They're required.
You can have both cswskax8.ocx and cswskax6.ocx
running and registered on the same machine. They're
two different versions of the same product and because
they have different file names and internal GUID's
they can coexist without issue. The version 1.8 of the
raw socket plugin needs the cswskax6.ocx to be present
and registered in order to run that version of the
plugin (you wouldnt change, unregister, or rename any
of the cs????ax8.ocx).
Maybe Im not understanding but when you unregister and
rename cswskax8.ocx PowerHome will NOT work.
Edited by dhoward - August 25 2015 at 20:41
| Posted: August 25 2015 at 19:46 | IP Logged
Ph 2.15d
I have unregister cswskax8.ocx , regiser cswskax6.ocx
also unregister Ph_socket 2.1 and register Ph_socket
1.8
checked in PH it shows the 1.8 plug in.
and Lockup again -
If I rename the cswskax8.ocx file the error so I left
it alone just unregister with regsvr32.
Nick
| Posted: August 25 2015 at 19:57 | IP Logged
Nick,
To run the 1.8 socket plugin and PowerHome you
MUST register BOTH cswskax8.ocx and
cswskax6.ocx. None of the cs????8.ocx files should be
unregistered or renamed.
| Posted: August 25 2015 at 20:30 | IP Logged
Okay register both and plugin 1.8 its up and pass 8
command - will watch and see, meanwhile I have download
2.15c on different computer still win 7 and will report
get back on both.
Nick
| Posted: August 25 2015 at 22:33 | IP Logged
no luck
2.1.5d with 1.8 plugin - locks up
different computer win7
2.1.5c with 1.9 plugin - locks up
only one which will take any beat up is
win 7
2.1.4 with plugin 1.8 - NO problem
| Posted: August 26 2015 at 17:31 | IP Logged
I can confirm (2 separate machine) that its works fine
with 2.1.4 and plugin 1.8.
I install 2.1.4 on 2nd machine where yesterday 2.1.5c
would fail.
Send and received many command without any problem.
Please let me know if you want me to try something
else.
Nick
| Posted: August 27 2015 at 11:17 | IP Logged
Nick,
Sorry to take so long getting back. I had a crash on
my virtual development machine and had to restore from
backup.
Last thing I'd like you to try (if you can) is to try
both version 2.0 and 2.1 of the Socket plugin on one
of your 2.1.4 machines so I can rule out an issue with
the new plugin.
To do this, you'll have to copy the cswskax8.ocx from
your 2.1.5 machine to your 2.1.4 machine and register
it. Don't unregister or rename anything else though.
If the 2.0 and 2.1 plugins run fine, then I can stop
tweaking the plugin and start looking at what changed
in the plugin frameword between PH 2.1.4 and 2.1.5.
| Posted: August 27 2015 at 12:50 | IP Logged
I copied cswskax8.ocx registered same with plugin 2.0.
So far it passed the 8 command test.
I will update when I get back home.
just FYI for last 30 hours 2.1.4 with 1.8 had no
problem and I was passing information to my main PH
thru Powerhome ph_ssrequest just to make sure trigger
and my macro also works.
Nick
| Posted: August 27 2015 at 17:25 | IP Logged
2.1.4 with plugin 2.0 - over 4 hrs and many commands
like over 60 - NO problem.
2.1.4 with Plugin 2.1 pass 8 command test and left it
on on to check it more.
so seems like no problem with plugin but something
difference between the PH version.
Nick
| Posted: August 27 2015 at 22:03 | IP Logged
both plugin 2.0 and 2.1 works with 2.1.4
Nick
| Posted: August 29 2015 at 00:58 | IP Logged
Nick,
Appreciate all the testing you've done. Its been a
huge help. Based upon your test results, I started
digging into the entire plugin framework and did find
a change that occurred between 2.1.4 and 2.1.5. I
created a special "torture test" plugin and can easily
make 2.1.5 hang.
The good news though is that I was able to make
changes to the 2.1.5 plugin frameword to put it more
in line with the way it was in 2.1.4 and I am no
longer able to crash it. The bad news is that this fix
won't be available until I release the next version of
PowerHome.
| Posted: August 29 2015 at 11:12 | IP Logged
Glad that we could isolate an error.
Do you have an idea what is the time frame for next
release, if it is few months then I can try writing my
own bridge.
for shot term I can leave my other laptop (2.1.4) ON
to do the back and forth communication like I mention
with ph_ssrequest
I don't want to be pushy but just like to know my
options.
Thank you
Nick
| Posted: August 29 2015 at 23:00 | IP Logged
Nick,
I need to finish up the Z-Wave support and a few other
bug fixes and improvements. This will be a full
release so will require a new help file, new database
upgrade utility, new install, etc. Its going to be
probably a couple of months before I can pull all that
together.
I might be able to pull the changes into a "patch"
2.1.5e version in a couple of weeks.
