| Posted: August 15 2015 at 22:05 | IP Logged
PowerHome 2.1.5d is now available for download. This is NOT a full release and is a collection of all fixes thus far applied to version 2.1.5c. Normally this would have been called 2.1.5c fix 6 (the 6th collection of fixes) but it was causing confusion with not having the actual version show any different from the original 2.1.5c.
Note that you MUST already have 2.1.5c (with or without previous fixes) installed before you can make use of this file. It is not a full installation and you'll just unzip it into your current PowerHome installation overwriting existing files.
This release includes fixes to the CPU-XA, Global Cache, Elk, Virtual Serial Port plugin, and the ph_geturl1 function.
Let me know if you have any issues.
http://www.power-home.com/download/ph215d.zip
