npavkov Groupie
Online Status: Offline Posts: 91
| Posted: February 20 2009 at 23:18 | IP Logged
I have macros which load graphics to the action graphic objects in cc, but when I run the macros I can not get the cc to show the updates when I initially start it up. How can I update the cc graphics before ever opening the cc. I find when I update one of the action graphics in cc after opening the cc then the other objects in my cc update accordingly.
also I can get my images (GIF) to display in PH cc but not in the web center, is there special settings I need to use in web center to get my images displayed??
| Posted: February 21 2009 at 08:41 | IP Logged
In Setup, there is a place to specify the CC startup macro.
Are your images under the Powerhome/web folder? If not, move them there or use the graphical web CC (/ph-cgi/ccmap).
npavkov Groupie
| Posted: February 21 2009 at 13:34 | IP Logged
Tony, I do have my image files in powerhome\web directory, but only image placeholders are shown in web cc for all images. even under ccmap - ONLY placeholders.
| Posted: February 21 2009 at 14:30 | IP Logged
Hmm. Works here in ccmap but not normal. Will investigate.
npavkov Groupie
| Posted: February 23 2009 at 18:57 | IP Logged
Tony, thanks for your help, I found the problem.....When I updated to 2.1b, I forgot to change my file references on the devices.....
But I would still like to find a way to update the CC with initial updates when it starts up.... I would like to run a update cc macro when cc starts up.....Nick
| Posted: February 23 2009 at 20:20 | IP Logged
It was in Setup, but I can't find it now!
It was Setup, Control Center, Run Macro on Open.
Time to check the docs!
cruelkix Groupie
| Posted: February 27 2009 at 19:33 | IP Logged
Did anyone find out how to do this yet? I am curious myself. I would really like a web page that shows the up to date status of my device right as I open without having to hit my custom made refresh button .....
