         BrianCanada Newbie
           | Posted: June 19 2014 at 11:24 | IP Logged
I have been using PH for 10-15 years and it has always
 been
 reliable.  Now I had to upgrade to Win7 and my UIRT will
 not work in PH.  It is installed and functions in a
 program called IRcommand2 fine.  I get this error in PH.
 "Cannot find the phuirt.dll control.  Please install and
 register this control.  Commands will not be transmitted.
 " I also get this error when starting PH. "Error loading
 library.  Please check whether PowerBuilder Acessibility
 library can be located in the path." My x10 stuff works
 fine, but no IR.  Anyone run into this problem with Win7.
 I have installed into C:\Powerhome 2.1b Version:
 NOT CONNECTED.  ID: IRR.  USB-UIRT IR Controller.
 ID: X10-1.  CM11A X10 Controller.
 ID: X10WIRELESS.  CM17A X10 Transmitter
         nadler Super User
           | Posted: June 19 2014 at 11:50 | IP Logged
I've used USB-UIRT with both Win7 and Win8.  I believe I
 needed an updated driver which was available from the USB-
 UIRT site. If you're already using the latest driver (which
 is still years old as I recall) try uninstall and then re-
 installing the driver.
 Noel
         BrianCanada Newbie
           | Posted: June 19 2014 at 12:08 | IP Logged
Thanks for your reply.  I have the latest driver and I have
 installed removed and re-installed.  I don't think it is
 the driver because it works in the other program fine.  To
 me the ph in the phuirt.dll tells me it's something in PH.
 I am grasping at straws.  The program has worked so well
 over the years, you tend not to know alot of the inner
 workings.  Should there be a file phuirt.dll somewhere on
 my drive.  If there should be, where should it be if it is
 missing and how do I get it.  Thanks for any help.
         nadler Super User
           | Posted: June 19 2014 at 12:12 | IP Logged
There is a phuirt.dll in the Powerhome directory.  I
 believe it was part of the PH install but other would know
 if this is correct.
 Noel
         BrianCanada Newbie
           | Posted: June 19 2014 at 12:27 | IP Logged
It is in the PH directory date stamp June 2007. So I think
 maybe it is pointing to the wrong directory.  I originally
 let the install put it in the Program directory.  When I
 started to have problems, I checked the forum and someone
 said to install it in the root directory of C: so I
 uninstalled and reinstalled but still a problem.  darn
 Windows anyway.  Thanks.
           | Posted: June 19 2014 at 17:50 | IP Logged
Brian,
 You need to run this command to register your phuirt.dll:
 regsvr32 c:\powerhome\phuirt.dll
 This command must be run as an administrator and you should get a popup window that the DLL server was successfully registered.
 To fix your accessibility error message, see the 6th post of this thread  http://power-home.com/forum/forum_posts.asp?TID=2669&KW=acce ssibility
         BrianCanada Newbie
           | Posted: June 19 2014 at 18:41 | IP Logged
Thanks Dave, I knew you would have some ideas.  The second
 part of your answer fixed the error on the look for the
 database but the phuirt.dll is already registered and when
 I try to register it again I get this error.The module
 "c:\powerhome\phuirt.dll" was loaded but the call to
 DIIRegisterServer failed with error code 0x80020009
 Thanks again for your help.
           | Posted: June 19 2014 at 23:04 | IP Logged
Brian,
 The message you're getting on the phuirt.dll is typically caused by not running the regsvr32 command as an administrator (on Windows 7 and up its not just enough to be logged in as a user with administrative privileges).
 What I like to do is right click the command prompt icon and choose run as administrator. From the command prompt, I'll change to the PowerHome directory with cd\powerhome. From there, I'll run the regsvr32 command detailed in my other post.
 Give that a try and see where that gets us.
         BrianCanada Newbie
           | Posted: June 25 2014 at 10:11 | IP Logged
Finally got another chance to work on the system and got
 everything going finally.  Yes, running the command as
 administrator did the trick.  I did a completely new win7
 install, powerhome, usb-uirt, x10 cm17 and the error for
 the uirt still came up.  Ran the regsvr52 and it fixed it
 on the clean install.  Went back to my real machine and did
 the same thing and it fixed it too.  Thanks very much for
 your help Dave.  I sure did not want to loose this program
 after all these years because of MS.
 Brian.
