         progas Newbie
 Online Status: Offline Posts: 21
           | Posted: January 29 2014 at 19:39 | IP Logged
I just installed two access points 2443's for phase coupling to see if I can get my system to be a bit more reliable. I am seeing a lot of 'Link not found' for response link or control link on various devices, and motion sensors i2cs units not very reliable.
 As links go I can delete the link, and redo it and then it will come up verified for a few days, the bam back to 'no link found'. Is there any linking for the AP's other than say linking as controllers to my PLM that I need to do, or do I even do that?
           | Posted: January 29 2014 at 22:31 | IP Logged
Do nothing with the Access Points as far as PH is
 concerned.  They are not linked to any device including
 themselves.
 Was the 4 tap Set button test run between the Access
 Points to confirm they are in RF range of each other and
 on opposite 120v legs.
  Edited by grif091 - January 29 2014 at 22:33
         progas Newbie
           | Posted: January 31 2014 at 08:13 | IP Logged
Yep did the 4 button press setup, and it went smoothly, and they are on opposite legs. I did link them to the PLM, so I will remove that link. Hopefully this will resolve some comm issues I am having. I will give things a few days test to see what happens.
 Thanks for the help. I am slowly coming up to speed on PH, and I am liking it more and more.
