ibscas Groupie
Online Status: Offline Posts: 46
| Posted: November 09 2008 at 22:20 | IP Logged
I'm having some trouble figuring out the proper commands and syntax of things to get this to happen: I have two lights in my office, only one of which is controlled by the wall switch, so I want to have a trigger that says "if the switch is turned on after 4pm, turn on the second light".
In trying to do all of this, I have tried several things but just can't seem to get it working. Here is the Trigger I set up:
Action Type: Raw Formula
Action: if (hour(now())>16,ph_macro('ofc on all'),0)
Type: Insteon Direct in (ACK) - also tried without ACK
Trigger ID: Wall Sw
ID Number: From Any (tried several others as well)
Trigger Value: Fast On (tried also just ON)
The formula seems to work fine when I test it, but I can't get it to trigger from the light switch.
Any recommendations?
| Posted: November 10 2008 at 07:51 | IP Logged
I would try a Trigger Type of Insteon Group In with Trigger ID Number as 1 with a Trigger Value On. I'm assuming Wall Sw is linked to one of the office lights. In that case Wall Sw is issuing a Group command. A Trigger Value of Fast On would come from a double tap of the Wall Sw. Certainly possible but not what I would think would be the normal way of turning on the light. You can set up another trigger to recognize a Fast On and do a Fast On to the second light if desired.
| Posted: November 10 2008 at 08:06 | IP Logged
Is the PLC or PLM linked as a Controller?
ibscas Groupie
| Posted: November 10 2008 at 09:44 | IP Logged
grif091 wrote:
| I would try a Trigger Type of Insteon Group In with Trigger ID Number as 1 with a Trigger Value On. |
That didn't do the trick, thank you for the advice though. What exactly does 'trigger ID' do anyway? I've always wondered what should be set there.
BeachBum wrote:
| Is the PLC or PLM linked as a Controller? |
It is a PLC.
| Posted: November 10 2008 at 09:51 | IP Logged
If you go to Insteon Explorer under tab Links and select Wall Sw is the PLC listed in the Controllers window?
ibscas Groupie
| Posted: November 10 2008 at 10:10 | IP Logged
BeachBum wrote:
| If you go to Insteon Explorer under tab Links and select Wall Sw is the PLC listed in the Controllers window? |
It wasn't, but I added it as the controller. Still didn't fire the trigger.
| Posted: November 10 2008 at 10:31 | IP Logged
Your settings:
Trigger ID: Wall Sw
Mine that worked:
Action: if (hour(now())>08,ph_macro(“test”),0)
Type: Insteon Group In
Trigger ID: Hallway
ID Number: Any
Trigger Value: On (ox11)
Boolean: 1
ibscas Groupie
| Posted: November 10 2008 at 11:21 | IP Logged
Those settings are the same as mine:
Edited by ibscas - November 10 2008 at 11:21
| Posted: November 10 2008 at 11:37 | IP Logged
I’m not familiar with the SwitchLinc Relay. I would imagine it wouldn’t make any difference in the protocol. But can you turn on Raw Log and post it?.
| Posted: November 10 2008 at 12:56 | IP Logged
You can also invoke Control/PowerHome Status. This displays the Event Log which should show an inbound Insteon Group message, a Trigger activation if it occurs and a Macro invocation if that occurs, plus whatever outbound Insteon commands that are issued. Will show you the sequence of events that occur when you turn on the wall switch. The event log is dynamically updated under PowerHome Status so you can invoke that first and then turn the wall switch on. Post back the raw Insteon trace and the PowerHome Status Event Log. Between the two should be able to tell how far the sequence got.
Pete, I'm heading back outside to attack the brown snowflakes. The SwitchLinc relay should not make any difference inbound. Actually outbound you can even request a bright level which is ignored.
