         k2zs Senior Member
           | Posted: November 11 2011 at 07:34 | IP Logged
I am suddenly getting an excessive amount of event03 in my
 reports and certain devices have been sending a larger
 number of NAK's. Nothing new really, is that a sign that I
 should replace the PLM?
 If changing the PLM is recommended should I choose to go
 with a "dual band" device? I'm assuming that other dual
 band devices are required so are there any "repeaters" that
 can be plugged in around the home or would I have to
 replace switches to gain any benefit?
 Home Automation Ideas
           | Posted: November 11 2011 at 09:45 | IP Logged
The increase in 03 events and NAKs could indicate a PLC problem.  Could also indicate some issue on the powerline, noisy appliance, UPS attenuating signal, cell phone charger, the list goes on.
 The Dual Band PLM alone can act as an interface for RF only devices such as Motion Sensors, TriggerLincs, RemoteLincs, RemoteLinc2s.  If not using Access Points for coupling the 120V phases that could also explain some of the 03 events and NAKs.
         k2zs Senior Member
           | Posted: December 02 2011 at 07:39 | IP Logged
Thanks Lee, I think I will be upgrading the PLM soon.
