rtt3821 Newbie
| Posted: July 06 2010 at 21:03 | IP Logged
I have tried to install the downloaded 30 trial version of PowerHome but keep getting an error message that there are corrupt files, Is PowerHome compatible with Windows 7?
sjvonstein Groupie
| Posted: July 07 2010 at 07:18 | IP Logged
It is compatible. Be sure you have administrator rights. Furthermore, disable UAC if you feel comfortable doing so, and then right-click on the installation file and click "Run as Administrator"
| Posted: July 07 2010 at 08:24 | IP Logged
I run on both Win7 and Vista. Although it sounds like your download failed. I would download the file again then install taking the defaults. Then do what sjvonstein suggested. If you still have a problem post the details here.
rtt3821 Newbie
| Posted: July 07 2010 at 14:19 | IP Logged
I re-downloaded the file and chose "run as administrator" and I still get the same error message,"The configuration data for this product is corrupt. Contact your support personnel".How do I correct this problem?
| Posted: July 07 2010 at 14:39 | IP Logged
Doesn’t sound like a PowerHome problem. I would try running CCleaner and see if that fixes it. Do you also get an error number?
| Posted: July 07 2010 at 15:44 | IP Logged
Here’s a little tidbit I found but don’t know if it pertains to you.
Here's what worked for me:
In the Registry Editor delete the entire
HKey_Current_User\Software\Microsoft\Installer key.
rtt3821 Newbie
| Posted: July 07 2010 at 17:18 | IP Logged
Thanks for your responses. I don't get an error number. Will Deleting the registry key cause any problems?
| Posted: July 07 2010 at 18:23 | IP Logged
You might want to backup the register just in-case but I don’t believe it would be a problem.
This is what mine looks like.
HKEY_CURRENT_USER\Software\Microsoft\Installer
HKEY_CURRENT_USER\Software\Microsoft\Installer\Assemblies
HKEY_CURRENT_USER\Software\Microsoft\Installer\Assemblies\C: |Program Files|Simplehomenet|SHN Utility Suite|Interop.SDM3Server.dll
HKEY_CURRENT_USER\Software\Microsoft\Installer\Assemblies\C: |Program Files|Simplehomenet|SHN Utility Suite|Simplehomenet Utility Suite.exe
HKEY_CURRENT_USER\Software\Microsoft\Installer\Features
HKEY_CURRENT_USER\Software\Microsoft\Installer\Features\5B99 6E3BEEE71BA47ABB4AB3B7D449DE
HKEY_CURRENT_USER\Software\Microsoft\Installer\Features\5C04 822FF182EA7469CCC26D7D176B41
HKEY_CURRENT_USER\Software\Microsoft\Installer\Features\6BBF DF96D153C8B4988D68D79C0D2A4A
HKEY_CURRENT_USER\Software\Microsoft\Installer\Features\CA53 85F66D1AE0F40A4A51E65895564E
HKEY_CURRENT_USER\Software\Microsoft\Installer\Products
HKEY_CURRENT_USER\Software\Microsoft\Installer\Products\5B99 6E3BEEE71BA47ABB4AB3B7D449DE
HKEY_CURRENT_USER\Software\Microsoft\Installer\Products\5C04 822FF182EA7469CCC26D7D176B41
HKEY_CURRENT_USER\Software\Microsoft\Installer\Products\6BBF DF96D153C8B4988D68D79C0D2A4A
HKEY_CURRENT_USER\Software\Microsoft\Installer\Products\CA53 85F66D1AE0F40A4A51E65895564E
HKEY_CURRENT_USER\Software\Microsoft\Installer\UpgradeCodes
HKEY_CURRENT_USER\Software\Microsoft\Installer\UpgradeCodes\ 3C7D85F192911FF4C809F64EF2802F45
HKEY_CURRENT_USER\Software\Microsoft\Installer\UpgradeCodes\ 7224ECCC6BF7B2A459BE93BD0A673F56
HKEY_CURRENT_USER\Software\Microsoft\Installer\UpgradeCodes\ BE094BE37F321114BB87A1746A498BC8
HKEY_CURRENT_USER\Software\Microsoft\Installer\UpgradeCodes\ FCADAC80A127C2447B673F04CC54F8B5
