Stellar Newbie
Joined: September 12 2010 Location: Russian Federation
| Posted: September 12 2010 at 23:24 | IP Logged
Hi! Can I change the codepage in the database?
| Posted: September 13 2010 at 16:56 | IP Logged
Stellar,
The only way I know to change the codepage is to rebuild the database file (cant do this in runtime version deployed with PH...must be full ASA client) and specify a new codepage.
Can you let me know what codepage you're looking for and I can see if I can make you a special version?
Stellar Newbie
| Posted: September 13 2010 at 22:29 | IP Logged
I need a Russian code page 1251.
| Posted: September 14 2010 at 19:39 | IP Logged
Stellar,
Im going through my available options and I don't have a Russian 1251. The only 1251 option I have is Cryllic.
I have several other options that are Russian however:
819
850
866
Would any of these work for you?
Stellar Newbie
| Posted: September 14 2010 at 22:58 | IP Logged
Yes, 1251 (Cyrillic) codepage this is the Russian code page. In 1251 (Cyrillic) codepage need a file pwrhome.db.
| Posted: September 15 2010 at 12:21 | IP Logged
Stellar,
I created a version of the PH database with a 1251 Cryllic codepage. You can download it here http://www.power-home.com/download/ph21b_1251cryllic.zip. Just unzip it and copy it to your powerhome\database directory. You need two copies, one should be pwrhome.db and the other should be ph21b.db.
Let me know how it works for you.
Stellar Newbie
| Posted: September 16 2010 at 10:08 | IP Logged
Thanks Dave!
Everything works fine!
