        | andyR Newbie
          When trying to enable the scripting server, I get the following error:
           | Posted: May 22 2010 at 23:29 | IP Logged |   |
 An error occurred while creating the script server: -3
 Now, I know that this error has been batted around this forum before, and a fix has been proposed for people who don't have PH installed in the default directory (which I don't since that seems to be necessary for it to work with win7-64).  Anyway, I've tried the editing the phsrc.reg script, and I've updated the path to where PH is actually located (C:\powerhome).  Yes, I did keep the double \\ in there.  I then did the merge and restarted PH (actually rebooted, just to be sure).  Still get the error.  I also did a regedit to check the registry value, and it is what I expected.  I then cut-n-pasted the value of the key in a cmd window 'dir' command to make doubly sure the phscr.pbd file pointed to by the key actually exists; it does.  I'm all out of ideas.  Anybody know what else I can try?  Thanks for your help.
 andy
        | sjvonstein Groupie
          Need this bumped.  Having the same problem on Win7 64.  Can't start the script server, and as a consequence, can't seem to run VB scripts.
           | Posted: May 26 2010 at 13:14 | IP Logged |   |
        | kikabyte Newbie
          Add me to the list! Been trying for a few weeks now.
           | Posted: June 12 2010 at 01:37 | IP Logged |   |
        | sjvonstein Groupie
          I got this running on Win 7, but I'm not entirely sure how.  I did a search on Microsoft's site for WSH (Windows Script Host) and ran whatever program I could find, regardless of operating system compatibility.  After a reboot, I was able to get the script server running.  Another thing that is very important is the reg file:  phscr.reg
           | Posted: June 12 2010 at 08:23 | IP Logged |   |
 |  The second to last entry should match where you have installed powerhome.  Modify it as needed.  You must maintain the formatting they have in that file, (ie the "//" in the directory structure)
 If you have any specific questions, post them here.
        | andyR Newbie
          I'm pretty sure that I have the 2nd to last entry in the phscr.reg file right; it points to c:\\powerhome\\phscr.pbd which is where I installed PH.
           | Posted: June 12 2010 at 12:33 | IP Logged |   |
 |  If you have any more hints on what programs you ran off of Microsoft's site, that would be very useful.  Thanks.
 andy
        | sjvonstein Groupie
          Did you merge the data with the registry after (and if) you made any changes?
           | Posted: June 12 2010 at 13:05 | IP Logged |   |
        | andyR Newbie
          Yes.  A more or less full description of what I tried can be found in the original post.  I think I followed all the instructions from prior posts correctly....
           | Posted: June 12 2010 at 18:15 | IP Logged |   |
        | sjvonstein Groupie
          Run this: (it might fail)
           | Posted: June 12 2010 at 21:19 | IP Logged |   |
 |  http://www.microsoft.com/downloads/details.aspx?FamilyId=D7E 31492-2595-49E6-8C02-1426FEC693AC&displaylang=en
 and this:
 http://www.microsoft.com/downloads/details.aspx?familyid=478 09025-D896-482E-A0D6-524E7E844D81&displaylang=en
 I recommend running them one at a time, rebooting, and see what happens before you run the other.  It would be nice to isolate what needs done so that it can be posted to the site permanently.
        | andyR Newbie
          Finally got back to trying this.  I tried both of these downloads, one at a time with a reboot in between.  The first one installed without a problem, but I still had the same PH error after it.  I tried the second download, but the install failed saying I don't have enough disk space (I do, so something is wrong with the install or something else).
           | Posted: June 20 2010 at 12:53 | IP Logged |   |
 I'll still play around with this in the background and will post an update if I get anything to work (assuming I can follow my trail of things I've tried).  For now, I've just opened up the socket communication and talk to PH directly from vb.net if I need to script something.
