        | jonkjon Groupie
          I have a keypadlinc configured for six buttons. Button 5
           | Posted: July 02 2010 at 23:21 | IP Logged |   |
 |  controls a togglelinc relay for one set of my deck lights.
 I have the keypadlinc and the togglelinc cross linked and
 working fine. I can turn off the deck light from either
 switch and PH sees the status change just fine as does the
 keypadlinc. I can also turn the deck lights off from PH
 just fine. However, the keypadlinc, (button 5) doesn't
 change status when I turn the lights off from PH.
 From the Insteon Explorer in PH, the keypadlinc and the plm
 each show up as both a responder and a controller for the
 deck lights. What am I missing here? Thanks in advance for
 your help.
 Edited by jonkjon - July 02 2010 at 23:22
        | grif091 Super User
          The ToggleLinc linked as a Controller with KPL button 5 as a Responder has no affect when you send an Off command from PH to the ToggleLinc.  Insteon architecture does NOT propagate the Off command to the ToggleLinc as a Responder such that the ToggleLinc then becomes a Controller and it's Responder(s) turn Off.  For PH to turn off multiple Responders (ToggleLinc and KPL button 5) you have to create a Scene where the ToggleLinc and KPL button 5 are Responders.  Then turn the Scene On or Off.
           | Posted: July 03 2010 at 01:59 | IP Logged |   |
 Lee G
        | jonkjon Groupie
           | Posted: July 03 2010 at 14:53 | IP Logged |   |
| Quote:
 hmmmmm......i'm new to PH terminology. Is this scene a group?
        | grif091 Super User
          Sorry, yes.  A Scene is a Group.  As far as Insteon architecture is concerned there are only Groups.  You will not find the term Scene used in the Insteon Command reference.  Smarthome uses the term Scene in much of the end user level literature which is really referring to a Group.  On the various forums you will find the term Scene and Group used pretty much interchangeably.
           | Posted: July 03 2010 at 15:02 | IP Logged |   |
 Lee G
        | jonkjon Groupie
          Got it! Thank you very much for the info and the clarification. I'll give this a try and be sure to post back with my results. Thanks again!
           | Posted: July 03 2010 at 15:09 | IP Logged |   |
        | jonkjon Groupie
          Set it up like you said and it worked like a charm! Thanks!
           | Posted: July 04 2010 at 16:57 | IP Logged |   |
