        | MrGibbage Super User
          It looks like the real Power Programmers here like to use
           | Posted: January 28 2010 at 15:11 | IP Logged |   |
 |  the direct SQL commands to get things done.  Sounds like a
 good idea to me, and I think it will simplify a lot of my
 macros.  Is there a list of tables somewhere that PH uses?
 I think I can figure out what to do from there.
        | grif091 Super User
          The following link to a very old post may provide some of the information you are looking for.  I am afraid that what you attribute to Power Programmers is really just the export of a Macro definition.
           | Posted: January 28 2010 at 19:00 | IP Logged |   |
 Powerhome Database
 Lee G
        | device Newbie
          Here is the first VBScript I ever wrote which will answer your question. It writes all tables, columns and column types out to a file. I have stuck with VBScript to do all the progammatic work because the environment while new to me then was more familiar. Maybe you will find this useful in enumerating all tables and columns for SQL manipulation.
           | Posted: February 01 2010 at 16:29 | IP Logged |   |
 D
 Function enumtables()
 On Error Resume Next
 enumtables = "failed"
 Set fso = CreateObject("Scripting.FileSystemObject")
 Set tableinfo = fso.CreateTextFile("c:\Program Files\powerhome\tables.txt", True)
 Set fso = Nothing
 sysstatus = ph.sqlselect(1, "SELECT * FROM sys.syscatalog")
 If (sysstatus = 0) Then
 enumtables = "success"
 tablecount = ph.getsqlrows(1)
 For tableindex = 1 To tablecount
 tablename = ph.getdata_cn(1, CLng(tableindex), "tname")
 If tablename <> "SYSUSERPERM" Then
 tablestatus = ph.sqlselect(2, "SELECT * FROM " & tablename)
 tableinfo.WriteLine("Table : " & tablename)
 If (tablestatus = 0 Or tablestatus = 2) Then
 colcount = ph.getcolcount(2)
 For colindex = 1 To colcount
 colname = ph.getcolname(2, CLng(colindex))
 coltype = ph.getcoltype(2, Clng(colindex))
 tableinfo.WriteLine("      " & CStr(colindex) & " : " & colname & " : " & coltype)
 Next
 Else
 enumtables = "success with errors"
 tableinfo.WriteLine(" &nb sp;    Error " & CStr(tablestatus) & " opening " & tablename)
 End If
 tableinfo.WriteBlankLines(3)
 ph.sqldestroy(2)
 End If
 Next
 ph.sqldestroy(1)
 End If
 tableinfo.Close
 Set tableinfo = Nothing
 End Function
        | device Newbie
          A "&nb sp;" snuck in there when the message was converted to HTML which should be removed.
           | Posted: February 01 2010 at 16:32 | IP Logged |   |
 D
          I have connected to the PH database with Access over ODBC.
           | Posted: February 02 2010 at 09:40 | IP Logged |   |
 |  Wow, I had no idea there were so many tables!  I now have
 the information I need to start playing.
 You script does look useful.  I think I will be able to use
 it in other situations like this as well (outside of PH).
        | device Newbie
          Actually the VBScript assumes it is running in PH. I wrote this a while back to begin to become familiar with VBScript, SQL and PH. I do a fair amount of SQL using VBScript in servicing PH events. If you need to manipulate the tables outside of PH and you have and are familiar with Access then that probably is the way to go. Have fun,
           | Posted: February 02 2010 at 13:59 | IP Logged |   |
 D
