        | jeffw_00 Super User
          I would like to find a way to export the database so that it can be parsed by, say, a perl script.  I want to use this to compare 2 databases and look for differences.
           | Posted: November 14 2009 at 13:25 | IP Logged |   |
 I had been exporting the database using this script...
 insert into macroheader values ('DBEXPORT','DB Export',0,0,1);
 insert into macrodetail values ('DBEXPORT',1,15,'[LOCAL2]',NULL,'"c:\jeff\insteon\db\exporteddb_" + string(today(),"yyyy-mm-dd")',0,'');
 insert into macrodetail values ('DBEXPORT',2,15,'[LOCAL3]',NULL,'1',0,'');
 insert into macrodetail values ('DBEXPORT',3,26,'',NULL,'LOOP',0,'');
 insert into macrodetail values ('DBEXPORT',4,15,'[LOCAL1] ',NULL,'ph_regexdiff1(",",",",",macroheader,macrodetail,inst eondevices,timedevents,triggers,exit,",1, [LOCAL3],0,0,0)',0,'');
 insert into macrodetail values ('DBEXPORT',5,16,'',NULL,'if("[LOCAL1]" = "exit",999,1)',0,'');
 insert into macrodetail values ('DBEXPORT',6,38,'',0,'ph_sqlselect(1,"select * from [LOCAL1] order by 1,2") + ph_writefile("[LOCAL2].htm",0,ph_gethtmldata(1)) + ph_sqldestroy(1) + ph_addtovar(1,3,1)',0,'');
 insert into macrodetail values ('DBEXPORT',7,27,'',NULL,'"LOOP"',0,'');
 Which, to be honest, I'm not sure I understand.  I think I got it from a thread that suggested that this data could be used to re-construct a corrupted database, so now when I do a backup I run this script in addition to generating a backup file, but now I'm wondering if the output file is useful for anything except viewing (which might have been the original purpose, not sure).
 Anyway, if I try to convert this HTML to text, I get tables with multi-word headers and blank table entries, so it's impossible to parse a row because the number of tokens varies so widely.
 I guess I'm wondering if there's a way to write the database out in something like CSV format, and also whether there's a way to export the entire database that will allow easy import (i.e., an ASCII backup).
 Edited by jeffw_00 - November 14 2009 at 13:29
        | jeffw_00 Super User
          bump?
           | Posted: December 05 2009 at 14:51 | IP Logged |   |
        | jeffw_00 Super User
          aw, come on guys  - it's a legitimate question 8-}
           | Posted: December 20 2009 at 17:27 | IP Logged |   |
 |  /j
        | kev21986 Senior Member
          This is an interesting question. There should be a way to
           | Posted: December 21 2009 at 12:17 | IP Logged |   |
 |  dump the database to sql. You could then parse the sql find
 and fix the problem in the sql script. Then clear the
 database and run the script. This is all theory though. No
 idea how to go about doing it in PH.
 I would be interested in a way to backup and restore the
 database. There is a lot of time put into setup and it would
 be really sad if it was all lost.
 Kevin Smith
 @respectTheCode
        | Back to Top |       |
        | grif091 Super User
          Backing up the PH database is as easy as making a copy of pwrhome.db   All the macros, triggers, device definitions, link information are contained in that one file.
           | Posted: December 21 2009 at 13:10 | IP Logged |   |
 Lee G
        | BeachBum Super User
          You also need to backup the INI file.
           | Posted: December 21 2009 at 13:46 | IP Logged |   |
 Pete - X10 Oldie
        | jeffw_00 Super User
          Yup - I wrote a perl script that copies and renames both these files with a date extension.  Then I wrote a macro to call the perl script.  Then I created a control center button to call the macro.  Push the button, get a backup.
           | Posted: December 21 2009 at 13:50 | IP Logged |   |
 However, when I code in my day job, I always like, when I'm done, to compare what I did with what I started with.  There's no easy way to do this within PH.  If there was a reasonable way to write out the database, a little perl could do a compare and DIFF the parts that changed...
        | BeachBum Super User
          I do a
           | Posted: December 21 2009 at 13:56 | IP Logged |   |
 PH_BACKUPDB ( "C:\POWERHOME\BACKUP\PH_CHC.DB", 1)
 Then
 ph_copyfile("C:\POWERHOME\BACKUP\PH_CHC.DB", "C:\POWERHOME\BACKUP\PH-CHC"   + " " + string (month (today())) + "-" + string (day (today()))+ " " + string (hour(today())) + string (minute(today())) + ".DB", 9)
 This is in a macro that fire every night.
 Pete - X10 Oldie
        | TonyNo Moderator Group
          I agree that an export option would be nice, but it would be HUGE! lol
           | Posted: December 21 2009 at 21:58 | IP Logged |   |
        | Back to Top |       |
        | jeffw_00 Super User
          huge = big file? or
           | Posted: December 21 2009 at 22:10 | IP Logged |   |
 |  huge = big effort?
 I actually doubt the latter.  I'd be willing to bet there's an SQL command that would do a nice job.
        | jeffw_00 Super User
          hey beachbum- why do it every night?  I do it only after I make a change - am I missing something?
           | Posted: December 21 2009 at 22:11 | IP Logged |   |
 |  /j
        | BeachBum Super User
          I make changes all the time as I am playing so I never know…
           | Posted: December 21 2009 at 23:09 | IP Logged |   |
 Pete - X10 Oldie
           | Posted: December 22 2009 at 08:12 | IP Logged |   |
| jeffw_00 wrote:
       | huge = big file? or huge = big effort?
 |  |  |  Big file.
        | Back to Top |       |
        | jeffw_00 Super User
          my PC has a TB drive, I think I can handle it 8-}
           | Posted: December 22 2009 at 09:49 | IP Logged |   |
           | Posted: December 22 2009 at 22:36 | IP Logged |   |
 |   Ya got me there. |
        | Back to Top |       |
        | RichardL Senior Member
          Is there a problem if a backup is executed while the application is running and the database is open?
           | Posted: December 29 2009 at 12:09 | IP Logged |   |
 I shutdown PH, do the backup and restart PH...
 Thanks.
        | BeachBum Super User
          I do mine in the middle of the night from a macro. So the answer would be no.
           | Posted: December 29 2009 at 13:09 | IP Logged |   |
 Pete - X10 Oldie
        | hotcoffee76 Newbie
          There are lots of tools out there that can compare databases.  I'm sure there is something for < $100.  The cost may be worth it depending on how much time it will take to write the parsing and compare routines.
           | Posted: December 30 2009 at 14:13 | IP Logged |   |
