        | judetf Senior Member
          I have a normal SwitchLinc that controls a bedroom light. I would like to create a situation where, if the light is on and you press the 'off' button the light turns off normally, but that if the light is already off and you press off, it fires a trigger (to turn the light on to a specific low-level).
           | Posted: January 09 2010 at 09:28 | IP Logged |   |
 But I can't seem to setup the Boolean field to prevent the trigger from firing if the light is already on (meaning that when I press the SwitchLinc to turn the light off it turns off but then the trigger fires and turns the light back on), and am getting results that confuse me.
 After failing to make it work with LOCAL9 and LOCAL10 variables, I decided to go for something more simple and set the Boolean to be: ph_getinsteonlevel("LIGHT") = 0
 Right now the light is on, and if I evaluate that Boolean field it evaluates to 'false'
 But when I press the SwitchLinc to turn the light off, the trigger fires! And I don't get it, and would appreciate someone pointing out what I am doing stupidly.
 I know there is probably a better way to compose the Boolean field, and I'm all for it, but I'd also like to understand why the trigger fires when, if I evaluate the Boolean before pressing the button that actually calls the trigger, it evaluates to false.
 jtf
        | BeachBum Super User
          Is this what you are trying?
           | Posted: January 09 2010 at 09:38 | IP Logged |   |
 if (ph_getinsteonlevel("LIGHT") = 0, 0,1)
 Pete - X10 Oldie
          That's not the actual code I'm using - What I posted above is the code I'm trying.
           | Posted: January 09 2010 at 09:43 | IP Logged |   |
 But that probably explains it: do I need the Boolean field to return a 1 or a 0 rather than a true/false? I guess that would explain my problem, and I'll give that a try. Thanks.
 Although if the light is off I want to evaluate to 1, so I'm switching what you wrote to
 if (ph_getinsteonlevel("LIGHT") = 0, 1,0)
 jtf
        | BeachBum Super User
          I really didn’t understand which way your trying to go but the end result is 1 if to trigger otherwise do nothing is 0.
           | Posted: January 09 2010 at 09:59 | IP Logged |   |
 Pete - X10 Oldie
        | TonyNo Moderator Group
          What type of trigger are you using?
           | Posted: January 09 2010 at 12:10 | IP Logged |   |
        | Back to Top |       |
          Still not working correctly.
           | Posted: January 09 2010 at 15:24 | IP Logged |   |
 It's a 'device change' trigger set to fire when the light is turned off, but the action is a raw formula to turn the light back on.
 So the trick I'm trying to accomplish is to only have the trigger fire if the light is already off when the switchlinc 'off' button is pressed.
 If the light is on, then the trigger shouldn't fire, so that the light turns off normally. If the light is already off, then I want the trigger to fire and have it turn the light on to a specific level via. That part works just fine. The problem is that the trigger is firing _every_ time I press the 'off' button, rather than only when the light is already off. Again, it's almost as if the Boolean field is being ignored.
          Okay, maybe the logs explain things, as the trigger seems to be firing twice in response to two different things (even though I'm only pressing the button once).
           | Posted: January 09 2010 at 15:35 | IP Logged |   |
 Immediately after the press, I see this:
 Insteon DM Controller PLM transmission of Address:[0D.1F.62] Flags:[15] Cmd1:[19] Cmd2:[0].  Decode: Direct. ID: LIGHT, Off
 Then the trigger fires
 Then a split-second later, I see:
 Incoming Insteon received on Insteon DM controller PLM. From Address:[0D.1F.62] To Address:[0F.D5.22] Flags:[35] Cmd1:[19] Cmd2:[0].  Decode: Direct ACK. From: LIGHT To: PLM, Off
 Then the trigger fires again, followed by a an Insteon Out that turns the light back on.
 So it must be that second string that I pasted which is causing the trigger to fire a second time and the Boolean value to be true (since the light is now off).
 So can someone help me understand what that second string above means, and how I can prevent it from happening?
        | BeachBum Super User
          1st you might try changing it to RT if (ph_getinsteonlevelRT("LIGHT") = 0, 1,0) but that response will be slow. Secondly Dave did not recommend running Insteon commands from the Boolean field in a trigger. It might be the level is not updated from a remote device until after the trigger has been received. If Lee is not raking leaves today maybe he’ll chime in.
           | Posted: January 09 2010 at 15:36 | IP Logged |   |
 EDIT: "Ships passing in the night" You might be able to block it with “trigdisable”. Search and you will find Dave’s comments on this.
 Edited by BeachBum - January 09 2010 at 15:41
 Pete - X10 Oldie
          My first efforts were to use LOCAL9 and LOCAL10, but that didn't seem to work, either.
           | Posted: January 09 2010 at 16:18 | IP Logged |   |
 As I understand it, LOCAL9 contains the value that the light was already at and LOCAL10 contains the new value that is being passed.
 Given what I'm trying to accomplish, I only want the trigger to fire if both are 0.
 Hmm, now that I think about it, I think I screwed that up when I was testing with LOCAL variables earlier. Let me try again with this as my Boolean [LOCAL9] = 0 and [LOCAL10] = 0
 That might be it...
          That was it. This was all a false alarm, because I couldn't think through my variables correctly.
           | Posted: January 09 2010 at 21:05 | IP Logged |   |
 Boolean = [LOCAL9] = 0 and [LOCAL10] = 0
 That did the trick. Now the trigger action only happens if the light was already off when I press the off button.
 Sweet, and sorry for the confusion.
 jtf
