        | doctorjerry Groupie
          Is powerhome compatible with Windows 7?
           | Posted: December 20 2009 at 23:20 | IP Logged |   |
 Jerome
        | BeachBum Super User
          Yes I’m running it on 7.
           | Posted: December 20 2009 at 23:23 | IP Logged |   |
 Pete - X10 Oldie
        | nadler Super User
          I just upgraded from XP Pro to Windows 7 Pro (64 bit) last
           | Posted: December 21 2009 at 07:53 | IP Logged |   |
 |  week and am running PH.  PH 2.1b runs right out of the box.
 The only issues I had were that W7 changed all my comm port
 numbers so I had to go into my macros and change them
 there.  Also one of my USB to serial converters doesn't
 work while a second one works, so I need to buy a new one.
 Lastly I needed a new USB UIRT driver (which I downloaded
 from their site).
        | BeachBum Super User
          PH runs fine but the sensitive issue is the drivers that Noel pointed out. Even though they may pass the Compatibility test they still might not work. I have also found some software is not upward compatible and I thought that was one of the advantages over Vista. Benchmarking the speed I found Win7 equal to XP and much faster than Vista.
           | Posted: December 21 2009 at 08:43 | IP Logged |   |
 Pete - X10 Oldie
        | kev21986 Senior Member
          I ran PH on Windows 7 for a few days without issues. I
           | Posted: December 21 2009 at 12:06 | IP Logged |   |
 |  ended up downgrading back to XP because of problems
 with other unrelated programs.
 Kevin Smith
 @respectTheCode
        | Back to Top |       |
