        | nick7920 Senior Member
          I just installed the (TriggerLinc - INSTEON Wireless Open/Close Sensor 2421) . Every time I open or close it sends the same data twice - I know, I can control that from my Macro,  anyone having the same issue ?
           | Posted: November 18 2009 at 21:53 | IP Logged |   |
 Thanks in Advance
 Edited by nick7920 - November 18 2009 at 21:54
        | grif091 Super User
          Are you seeing the two messages normally associated with a Group command or actually seeing 4 Group messages.
           | Posted: November 18 2009 at 22:54 | IP Logged |   |
 Lee G
          even in raw data in smarthome device manager , I see two times same data -
           | Posted: November 18 2009 at 23:33 | IP Logged |   |
          I spoke to Tech support of smarthome and they are sending another one - it should not send twice. I will post update when I get the replacement.
           | Posted: November 19 2009 at 19:31 | IP Logged |   |
 Edited by nick7920 - November 19 2009 at 19:32
          I got the new one , and it does the same thing. Can someone tell me what is the smarthome device manager version are you using. I have xp and my smarthome device manager version is 1.01.138.308
           | Posted: November 25 2009 at 20:09 | IP Logged |   |
        | grif091 Super User
          I was using .308 when the PLC was my Powerline interface.  You might be seeing two messages because both Access Points are receiving the TriggerLinc signal and each Access Point is putting the message on the powerline.  Try unplugging one of the Access Points.  Unplug the Access Point that is not on the same 120v phase as the PLC or you may lose the TriggerLinc message altogether.
           | Posted: November 25 2009 at 20:18 | IP Logged |   |
 Lee G
        | BeachBum Super User
          I’m using a PLM and all 3 of my Motion Sensors send 2 identical Group Ons. I unplugged 1 of my Access Points and I still see both. This does not pose a problem as I disable the trigger when I see the 1st one.
           | Posted: November 26 2009 at 12:25 | IP Logged |   |
 Pete - X10 Oldie
          I had Tried that and I tried again with only one Access point. I am still getting the twice the open command and some time no close command  it could be rang issue but when works with one access point still sending twice the command. I checked with another member who is also using the 2421 and confirm that he is also getting more than open command. It would be no problem if you are turning light, you would just sending twice to turn the light on. I am using TTS to know which door is opened. Now I have to modify my Macro to only run once within a minute. overall for wireless it could be good so we wont miss the open or close.
           | Posted: November 26 2009 at 12:45 | IP Logged |   |
        | BeachBum Super User
          The following is how I eliminate the double firing:
           | Posted: November 26 2009 at 13:20 | IP Logged |   |
 Pete - X10 Oldie
