        | MarkJames Newbie
          Hi,
           | Posted: November 21 2009 at 11:50 | IP Logged |   |
 |  I recently copied and pasted 6 or 8 responder links and got a blank line embedded in between them.  It doesn't seem to be a problem other than that when you tab into that line it does a 'select all'.  Is this normal behavior?  A spacer or something?
 Here it is.... group 205 between KPL-MASTERNAZ and LIGHT-SPIRAL
        | BeachBum Super User
          I see this all the time and figured it was some kind of separator. It does not appear to make a difference and it usually occurs within 7 or more lines down once.
           | Posted: November 21 2009 at 12:04 | IP Logged |   |
 Pete - X10 Oldie
        | grif091 Super User
          The space appears at times between groups of links with the same group number.  It is an artifact of the process of constructing the display table.  It does not represent a problem with the links themselves.  The "flagged create" status represents links that powerhome has not yet written.  Insure the Enable Pending option is checked and the device is not marked Disabled or the "Clear Failed" column is not red shaded if those links are not eventually created by Powerhome background process.
           | Posted: November 21 2009 at 12:30 | IP Logged |   |
 Lee G
