        | kenbr Newbie
          i run powerhome as a service on a remote system that also handles vpn traffic.  the system is an amd athlon 2400+ with 768 meg of ram.  all it does is handle the vpn and powerhome.  task manager shows the load to be about nothing....
           | Posted: November 23 2009 at 19:24 | IP Logged |   |
 the problem that i'm having is that the vpn stutters when powerhome is running with status check for instion enabled.  disable that and the vpn is fine.
 i suspect that this is an interrupt problem (usb interrupts for the plm vs. ethernet interrupts for the vpn) more than a strict process priority issue, but i'd like to try dialing back powerhome's priority to below normal and see if this gives me some relief.
 is there a way to control powerhome's process priorities when running as a service?
 edit: this isn't a ph problem.  i'm just looking to bandaide this until i can upgrade some hardware.
 thanks,
 ken
 Edited by kenbr - November 23 2009 at 22:38
        | BeachBum Super User
          You might try Process Explorer to set PH to a lower priory for testing but that won’t do it permanently.  You really don’t need to run scan unless there is some major change.
           | Posted: November 23 2009 at 23:25 | IP Logged |   |
 Pete - X10 Oldie
        | kenbr Newbie
          process explorer - it'll do fine.  thanks pete!
           | Posted: November 23 2009 at 23:38 | IP Logged |   |
 ken
