| Posted: May 06 2022 at 10:35 | IP Logged
After a major disk crash, I just reinstalled PH, but now when I try to Setup the Web interface I get a missing webserver|menutitle error message which is also a fatal PH error that terminates execution...
Is there any way to fix that without having to reinstall ph22beta3.3?
| Posted: May 07 2022 at 00:11 | IP Logged
Ken,
What do you have showing for this value in PowerHome Explorer under Setup->Web? You may need to manually look at the pwrhome.ini file to see what is
stored under the [webserver] section for menutitle7.
I suspect there is an illegal character or something is not filled out properly. If you cant see anything wrong, post the full menutitle and menuurl
settings that you've got.
