npavkov Groupie
Online Status: Offline Posts: 91
Posted: October 03 2006 at 23:05 | IP Logged
I have successfully upgraded to new beta version 1.03.4.8, and converted the db fine also. However I have a problem because I have a startup macro which minimizes PH to the system tray (and locks out the click to bring it up from the tray....for security reasons.) However, I forgot to rename the startup macro before upgrading and now I can not get PH to allow me to access it (since the controllers are gone from upgrading, and I utilized a remote x10 switch to bring it up from system tray to access it)
IS there anywhere to keep the startup macro from running on startup, when I can not access PH to rename it or anything in the db..... Help please!!!!
Posted: October 03 2006 at 23:27 | IP Logged
You should be able to modify the pwrhome.ini file...
[Script]
STARTUPMACRO=
Edited by TonyNo - October 04 2006 at 00:01
npavkov Groupie
Posted: October 04 2006 at 07:49 | IP Logged
Thanks Tony, I will try that later today......
krommetje Super User
Posted: October 04 2006 at 09:53 | IP Logged
When can it be downloaded?
Peter
Posted: October 04 2006 at 13:33 | IP Logged
It's available now. See Dave's recent post.
