         PhilC Newbie
 Online Status: Offline Posts: 39
           | Posted: February 27 2020 at 19:18 | IP Logged
I am running custom html pages (stored in the PH Web
 dir) on a windows tablet and also an android tablet.
 The windows tablet performs fine as I can access the
 html pages over the local network but the android
 tablet has to communicate with PH through HTTP which
 is extremely slow. It takes about 15 seconds to load
 the page of which 12 of those seconds are waiting for
 the server to reply. This is indeed the case using any
 machine to talk to the PH server over http. Is there
 anything I can do to speed it up?
 Phil
           | Posted: February 28 2020 at 18:26 | IP Logged
Phil,
 Im not sure if I fully understand. If I have this right, a Windows tablet on the same local network as PowerHome has no problem
 accessing the webpages (all web pages are accessed as HTTP unless you've actually got a "drive mapping" to the PowerHome web
 directory and are accessing the HTML files as a file vs a webpage). An Android tablet however (not sure if it's on the local network
 or comes in via the internet or what) is very slow to open the same webpages.
 Trying to understand what you're saying, Im assuming that the Windows tablet is indeed mapping the PH directory and directly opening
 the HTML files as a file and the Android tablet (probably on the same local network) is accessing the HTML pages as a webpage from
 the PH Web server.
 If I have that right, Im not quite sure why that would be.  Accessing the pages via the webserver will be slower than direct access
 as a file as you have more steps involved (PowerHome has to first open the HTML page as a file, read it into memory, and then send it
 down a socket using the HTTP protocol) but it shouldnt be that slow.  Im not using many custom pages in my own setup but all of pages
 render within a second or two whether Im on the local network or internet on both Windows and Android devices.
 Do the internal PowerHome pages also take a long time to load or are the reasonably responsive?  The custom pages that you're
 serving, about how large are they and do they call in alot of different external objects (graphics, javascript libraries, etc)?
 I could probably troubleshoot a little better if you could zip up and email me a sample HTML that you're having a problem with along
 with any embedded objects.  Also, what version of PowerHome are you running?
         PhilC Newbie
           | Posted: February 29 2020 at 14:21 | IP Logged
Yes Dave, you have that right. The windows tablet
 accesses the html pages over the same network
 (file://homeserver/web/music-screen.html) and the
 android tablet calls the html like:
 http://192.168.1.15:8080/music-screen.html.
 Whether it's the android tablet or indeed my laptop the
 speed issues are the same. The html files are extremely
 small and not graphics heavy.
 The issue is how long it is taking the PH server to
 respond. For example if I click a link to another page
 I will get about 10 seconds of 'waiting for
 192.168.1.15' and then when it does respond the page
 loads quickly. This behavior is confirmed by looking at
 chrome network performance that shows about 10 seconds
 of 'waiting time' before anything happens.
 Strangely, this issue, however, does not affect any
 interaction with PH in terms of clicking buttons to
 activate macros etc.
 To make matters more confusing, the problem is
 intermittent and is sometimes worse than others.
 This isn't a massive issue as the functionality is not
 affected, it just makes it a pain when I am developing
 the html pages as each page refresh is taking so long.
 Hope that makes sense!
 Phil
         Resolute Newbie
 Online Status: Offline Posts: 32
           | Posted: March 12 2020 at 20:34 | IP Logged
This has the classic symptoms of DNS resolution issues, not necessarily client to server, but server to resources. Is the webserver using DNS at all in collecting
 its resources?
