           | Posted: June 16 2020 at 11:27 | IP Logged
I presently control my Onkyo AVR's through serial
 control (either via a Global Cache or via direct
 serial connection).  With more and more appliances
 having wired/wireless ethernet connectivity, I am
 starting to play around with looking into how to
 control my receivers over wired/wireless ethernet via
 PH.
 For my Sony XBR tv's, IP control was accomplished with
 Dave's help here:
 http://www.power-home.com/forum/forum_posts.asp?
 TID=10783&KW=socket
 I have been looking into the same approach for my
 Onkyo recievers.
 The Onkyo reciever eISCP ("e"thernet Integrated Serial
 Control Protocal) messaging is slightly different than
 the direct serial protocal messaging (ISCP).
 Onkyo protocal documentation is attached here:
 From my web searching and testing with the "Packet
 Sender" utility (found here: https://packetsender.com/
 ), I can make my Onkyo receiver turn on/off, change
 volume, mute etc....
 The Packet Sender strings look like:(in ASCII)
 PowerOn:ISCP\00\00\00\10\00\00\00\08\01\00\00\00!1PWR0
 1\r
 Power Off
 :ISCP\00\00\00\10\00\00\00\08\01\00\00\00!1PWR00\r
 Power
 QSTN:ISCP\00\00\00\10\00\00\00\n\01\00\00\00!1PWRQSTN\
 r
 Vol 20
 :ISCP\00\00\00\10\00\00\00\08\01\00\00\00!1MVL14\r
 The Packet Sender strings look like:(in HEX)
 Power On  :49 53 43 50 00 00 00 10 00 00 00 08 01 00
 00 00 21 31 50 57 52 30 31 0d
 Power Off :49 53 43 50 00 00 00 10 00 00 00 08 01 00
 00 00 21 31 50 57 52 30 30 0D
 Power QSTN:49 53 43 50 00 00 00 10 00 00 00 0a 01 00
 00 00 21 31 50 57 52 51 53 54 4e 0d
 Vol 20    :49 53 43 50 00 00 00 10 00 00 00 08 01 00
 00 00 21 31 4d 56 4c 31 34 0d
 Similiar to what I did with my XBR TV's, I have set up
 a PH_Socket.phsocket plugin (called ONKYO_SOCKET") to
 send commands directly to the Onkyo IP address and
 control port (port 60128 by default). The plugin has
 the full initialzation data (192.168.0.83 60128).
 Like with the XBR tv's, I think it again comes down to
 how the PH_Socket.phsocket plugin handles special
 characters (FYI - from the Help:About:Plugins area:
 Raw Socket Plugin, Plugin Version is 2.4, SDK version
 is 1.2).
 I have tried most every variation that I can guess at:
 ph_picmd(2,"ONKYO_SOCKET",1,0,0,"ISCP0000000000000000~
 n","")
 My question likely centers around how the plugin
 handles (or doesn't handle) special characters.  I
 also have some uncertainty with respect to 8th and
 12th characters from the left (has to do with Onkyo's
 protocal and data field sizes).  Not being a computer
 engineer/scientist, I am a bit at a disadvanged here.
  16_121355_eISCP.JPG">
  Edited by smarty - June 16 2020 at 12:13
           | Posted: June 16 2020 at 12:38 | IP Logged
           | Posted: June 16 2020 at 20:30 | IP Logged
Steve,
 Should be doable as long as you're running the latest version of the ph_socket plugin dated 02/07/2019.
 Since you're going to be sending binary characters, you have to use a different command number and escape the binary characters (anything
 below ASCII 32 or above ASCII 128). Your Power On command would look like this:
  ph_picmd(2,"ONKYO_SOCKET",10,0,0,"\x49\x53\x43\x50\x00\x00\x 00\x10\x00\x00\x00\x08\x01\x00\x00\x00\x21\x31\x50\x57\x52\x 30\x31\x0d","")
 I didnt have to escape every character but just thought it would be easier to do so. When escaping characters, you start with a "\" and
 follow with either an "x" and 2 hex digits or 3 decimal digits so a carriage return can be escaped as either \013 or \x0d. The thing to
 remember is if you're using a command 10 (instead of a 1), you MUST escape the "\" character as either \x5c or \092.
 Your initialization data for the plugin should also be changed to: 192.168.0.83 60128 1
 The third parameter after the port (1) is a flag telling whether data returned by the socket should be escaped or not. I didnt get a chance
 to review the protocol to see if it was absolutely necessary but it cant hurt. A value of 0 (or not including the 3rd parameter) means that
 no returned data will be escaped. This could be a problem if binary data is returned. A value of 1 means to escape characters that fall
 outside of the range of printable ASCII characters. A value of 2 means to escape ALL returned characters. Returned data that is escaped will
 always be escaped in the decimal format.
 Anyways, hope this helps.
           | Posted: June 17 2020 at 14:54 | IP Logged
Thanks Dave, I would have NEVER figured it
 out...especially the "CMD" of binary "10" after
 "ONKYO_SOCKET".
 PWR01: On command looks like:
 \x00\x00\x10\x00\x00\x00\x08\x01\x00\x00\x00\x21\x31\x
 50\x57\x52\x30\x31\x0d","")
 PWR00: Off Command looks like:
 50\x57\x52\x30\x30\x0d","")
 The Plugin Trigger Returns info like:
 temp1= _ONK-SOCKET-TRIG temp2= 0 temp3= 62 temp4=
 60128 temp5= ISCP\000\000\000\016\000\000\000
 \001\000\000\000!1PWR00\026
  temp6= 27 temp7= ONKYO_SOCKET temp8= 1 temp9= 1
 temp10= 192.168.0.83
 The PWRQSTN: Power Question is trickier, because the
 string length is longer, and the data field size
 changes (note the "\x0a\" character...
 \x00\x00\x10\x00\x00\x00\x0a\x01\x00\x00\x00\x21\x31\x
 50\x57\x52\x51\x53\x54\x4e\x0d","")
 MANY MANY thanks again to you Dave!
           | Posted: June 20 2020 at 13:45 | IP Logged
 While I was indeed able to get this working with your
 help (again - thank you), it got me to thinking that
 maybe I have somehow/somewhere overlooked where there
 was instructions for how this PH_Socket.phsocket plugin
 works and the initialazation options available for it.
 The lastest PH "help" file for the socket plugin makes
 no mention of these options...or did I overlook
 something?
           | Posted: July 06 2020 at 09:51 | IP Logged
Steve,
 Sorry I missed this.
 Nope, you didnt overlook anything  . The additional command options and such are new in the current ph_socket plugin and had
 not been documented yet. I have since updated the latest Help file available in the 2.2 beta3 version with all current
 functionality.
