           | Posted: July 08 2020 at 11:33 | IP Logged
Hi - I'm using the latest release of PH (not the new beta), and saw
 some strange behavior this morning.  It stopped processing triggers.
 In the log I can see the triggers being detected, but no MACROs are
 called.  A restart fixed it, but it was weird.  If it happens again, is there
 anything I should look at?  Is there any place triggers can be globally
 disabled?
           | Posted: July 09 2020 at 15:59 | IP Logged
Jeff,
 My guess is that the execution queue crashed. With an older version of PowerHome (and new version), one way would be to look at the PowerHome Status
 screen and see if the Execution Queue is filling up and nothing being processed. You could also go the menu File->Debug Info to get a snapshot of internal
 variables that you can look at or send to me for review.
 On the newest version of PowerHome (2.2beta3), there is also a function that you can execute in the multi-editor called ph_stacktrace(). This function
 will show the whole state of the execution stack and can be useful in tracking down what may have caused a hang.
 If it happens again, before restarting, see if the File->Clear EXE Queue menu item does anything to restore normal operation.
           | Posted: July 09 2020 at 16:02 | IP Logged
Hmmm - timed events were still chugging along - (sorry, should have
 mentioned) - wouldn't that need the execution queue?  PH hadn't
 completely hung.  I could see activity in the log.  I could see triggers
 fire - but the macro they were supposed to trigger did not appear..
 weird...
           | Posted: July 09 2020 at 16:38 | IP Logged
Jeff,
 If Timed Events were processing (along with the associated actions which would have been sent to EQ), then the EQ probably wasnt hung.
 Not sure what else could do it unless the Boolean field was evaluating to 0 or false. A trigger will still fire but if this field is 0 or
 false then the action will not be performed.
           | Posted: July 10 2020 at 08:27 | IP Logged
It was several different triggered events that weren't showing up.  Ok -
 let it go..  Happened once in the many many years I've been
 running PH  :-)
  Edited by jeffw_00 - July 10 2020 at 08:28
