           | Posted: July 11 2020 at 16:55 | IP Logged
So happy       to see a new ph_run1() function
 that should allow for hiding pop up windows when
 running commands from within PH.
 Because the new FireTV plugin that comes with PH
 doesn't provide any feedback for triggers, I am
 looking into developing my own solutions (having ADB
 write to a text file and having PH file monitor
 trigger off that)...Anyway...that is another story.
 What I am trying to accomplish presently is to run
 ADB commands from PH without a pop up window.
 Home Command:
 ph_run("c:\adb\adb.exe shell input keyevent 3")
 Launch Netflix:
 ph_run("adb shell monkey -p com.netflix.ninja 1")
 Launch HDHomeRun:
 ph_run("c:\adb\adb.exe shell monkey -p
 com.silicondust.view 1")
 Ect, Etc,...
 Without a command window flashing on the screen as the
 command executes.
 Dave - I think I have tried almost every variation on
 the ph_run1() command.  Any insight you could provide
 here?
 One last one...this is how I see which application is
 on screen:
 ph_run("adb shell dumpsys window windows
 >c:\powerhome\ADB-Control\ADB_windows1.txt")
 The above command (which outputs a text file for the
 file monitor) works in a CMD window, but not from
 within PH.
  Edited by smarty - July 11 2020 at 17:58
           | Posted: July 11 2020 at 22:10 | IP Logged
Steve,
 You've got a couple of options listed below. Both will run ADB without opening a window.
 Without Shell Execute:
 ph_run1('c:\android_sdk\adb.exe','kill-server','',0,8)
 With Shell Execute:
 ph_run1('c:\android_sdk\adb.exe','kill-server','',0,20)
 The following worked for me to run ADB without a window and redirect output to a file:
 ph_run1('cmd.exe','/c "adb shell dumpsys window windows>ADB_windows1.txt"','c:\android_sdk',10000,72)
 and:
 ph_run1('cmd.exe','/c "adb shell dumpsys window windows>ADB_windows1.txt"','c:\android_sdk',10000,84)
 and another where I redirect the file output to a different directory:
 ph_run1('cmd.exe','/c "c:\android_sdk\adb.exe shell dumpsys window windows>adb_windows1.txt"','c:\users\hello there\desktop',10000,84)
 Out of curiosity, what kind of triggers would you like to be fired for the FireTV plugin? It might be simple enough for me to add.
