           | Posted: July 13 2020 at 20:08 | IP Logged
Rather than re-write some of my working code (that I
 want to update), I thought I would ask first....
 I have a Global Cache 100 in my living room that
 provides the a serial port for my TV (port 20), and
 one for my reciever (port 21).  The Global Cache
 plugin set up looks like below:
 GC-LVRM-PORT1, PH_VSP.phvsp, 20 4999 192.168.0.189
 CG-LVRM-PORT2, PH_VSP.phvsp, 21 5000 192.168.0.189
 Presently I am using the INTERNAL comm controls of PH
 for both of these two items  - see below:
 ph_comopen({COM NUM AVR LIVRM},{COM PORT AVR
 LIVRM},9600,"N", 8, 1, 1, 0, 0, 0, 0, 1, 1, "?","COM
 PORT AVR LIVE RM")
 and
 ph_comopen({COM NUM LIVING TV},{COM PORT LIVING
 TV},9600,"N", 8, 1, 1, 0, 0, 0, 1, 1, 1, "?","COM PORT
 TV")
 As Dave has stated in the past, PH has a limit of 5
 internal COM's, (and they run within the PH
 thread),...  .... but through the use of the ph_comm
 plugin, you can have many more COM controls, and they
 have the benefit of running in their own thread (the
 reason I want to convert to the ph_comm plugin).
 Here is my question:  Since I have to "define" the com
 ports (20 & 21) for the Global Cache in the PH Plugin
 Section, and if I change from PH's internal comm
 control to the external ph_comm plugin control which
 also has to be defined in the PH Plugin Section, will
 this lead to problems/issues regarding plugin load
 order or plugin start up timing?
 I would think I would want to define the Global Cache
 plugins first, and then define the ph_comm plugins for
 each port farther down the plugin list (question is,
 how much further down..and will this be an issue?)
 I have never put this combination of plugins together
 before and was looking to hear if anyone has any
 useful input.
  Edited by smarty - July 13 2020 at 20:11
