           | Posted: December 05 2018 at 14:39 | IP Logged
Dave-
 For a year I have been getting an error on PH Startup that says the IR Table is bad.
 I finally got feed up with this nagging and attempted to remedy it today however ...
 If I look at the IR Table using the PH SQL Editor the IR Table is empty.  BUT if I examine the IR Table, outside of PH, using Access the table has four entries in it. I can delete those entries but when I try to save the fix the table it is saved as an "pwrhome.odb"  which PH will not accept.
 If I change the Extension to "db" instead of "odb" the file is still non-useable.
 Can you suggest how I can get this all resolved?
  Edited by GadgetGuy - December 05 2018 at 14:40
           | Posted: December 05 2018 at 20:06 | IP Logged
Ken,
 If you've got an error with your IR table on PowerHome startup, it could be an issue with the relationship between your EQUIP and IR tables. The
 EQUIP table is the parent and the IR table is the child. If you've got IR entries with no corresponding EQUIP entries, then it would cause an
 error.
 If you're not currently using IR in PowerHome, the easiest way to clean these tables would be to open the PH Multi-Editor, change to SQL mode and
 then run the following SQL statements:
 delete from ir
 delete from equip
 With both tables empty, then the error should go away and you should be safe to start working with the IR screens from the PH Explorer.
