kfoster01 Newbie
Posted: September 20 2004 at 16:29 | IP Logged
I have upgraded to the new beta version. Followed all the upgrade direction but when I start PowerHome I am getting System[AUTOTIMEOUT] error message. I upgraded from ver 1.03.4
Posted: September 20 2004 at 18:27 | IP Logged
Kevin,
It sounds as if your pwrhome.ini file did not get upgraded by the phupg utility. Not to worry...if you open the changes.txt file in the PowerHome directory, you'll find a list of changes that occurred to the INI file at the end of the file. One of the changes was the inclusion of a new parameter to the [SYSTEM] section called "AUTOTIMEOUT". You'll see that it has a default value of 5.
In addition to this parameter, there are also a number of other parameters which must exist in the pwrhome.ini file in order for PowerHome to start. You can copy and paste them manually from the changes.txt file.
Let me know if you're still having problems or if this worked or not.
kfoster01 Newbie
Posted: September 20 2004 at 20:49 | IP Logged
Thanks Dave for your quick reply. All is working now!
