PowerHome Programming
Subject Topic: LG TV IP Control ?? Post ReplyPost New Topic
smarty
Super User
Super User
Posted: February 05 2018 at 06:47 | IP Logged Quote smarty
First off I haven't bought any TV's in a long a while. All of my present TV's (a Pioneer and a couple of LG's) use serial control that works well with PowerHome.
It seems like most of the newer and controllable TV's use wired or even wireless IP control via a dedicated app.
My question to this group is: Has anyone directly controlled their TV via IP using PowerHome?
If so, what do the connection and control commands look like from within PowerHome?
I am trying to determine if and how PH will work with a possible new TV by the hob tub.
smarty
Super User
Super User
Posted: June 18 2018 at 19:14 | IP Logged Quote smarty
Update - This particular LGTV DID NOT have serial control.
It didn't have the DB9 connector (which should have been my first clue), but it did have a stereo type jack that was labeled as possible serial control (but it wasn't).
Anyway...end up returning that TV and buying a Sony XBR TV with serial and IP control. Case closed.
