NorthernAl Groupie
Online Status: Offline Posts: 48
| Posted: March 17 2007 at 12:40 | IP Logged
I've been using PH for a while so it seems crazy to ask these simple questions but not knowing the answers bugs me!
- where is the log stored? in DB or disk file? If disk can it be deleted off disk?
- I ask because due to a clock problem on my pc I ended up with events in the future in my log. Hard to get rid of them (even with log trim command)
- is the only way to refresh the log window to close and reopen it? A refresh button would be nice.
| Posted: March 17 2007 at 14:41 | IP Logged
The log is in the DB.
I view the log via the web. Seems quicker and has a refresh button.
| Posted: March 19 2007 at 17:14 | IP Logged
The log is in the database in two tables...eventlog and weblog. You can get rid of events in the future with this SQL statement:
delete from eventlog where time_stamp > today()
When the eventlog report is open (and active), F5 will refresh the data.
Also, the PowerHome Status screen has a realtime eventlog window. You can size this window to be the predominant window if you like and change a setting in the pwrhome.ini file ([PowerHome Status] eventlogrows) to go from the default last 10 rows displayed to more if you like.
