           | Posted: December 08 2007 at 13:33 | IP Logged
how do I increment/decrement a global variable within a macro?
         bhlonewolf Senior Member
           | Posted: December 08 2007 at 14:08 | IP Logged
Probably a few ways to do it, but check out the ph_addtoglobal function ...
           | Posted: December 08 2007 at 16:39 | IP Logged
umm, yeah - if it handles negative values as well -
 that'll do it.
 thanks!
           | Posted: December 08 2007 at 17:50 | IP Logged
It does.
           | Posted: December 08 2007 at 17:54 | IP Logged
not in the obvious way, I needed to do...
 ph_addtoglobal("SLEEPINCNT",double(-1))
           | Posted: December 09 2007 at 10:12 | IP Logged
Yeah, I could see that from an end user point of view.  From a programmer's or a computer's point of view, all math is fundamentally addition.  In most APIs and what not, it gets a little cumbersome to wrap variants like subtraction, et al.  It's a fairly standard paradigm, but I see what you mean.   Just wait until you play with various DateTime APIs and to find yesterday, you add -1 days.  :)
           | Posted: December 09 2007 at 10:33 | IP Logged
sounds like you know your stuff, bh -I'm surprised you can't help me with..
  http://www.power-home.com/forum/forum_posts.asp?TID=1548&PN= 1
 8-}
  Edited by jeffw_00 - December 09 2007 at 10:34
           | Posted: December 09 2007 at 11:54 | IP Logged
The problem with negative numbers is that they *must* have a space before and after the negative to work properly (not my restriction but the language Im programming in).  Sometimes it works if you don't include the spaces, but for maximum compatibility, it's best to just always put them there.  So it should work like this:
 ph_addtoglobal("SLEEPINCNT", - 1)
           | Posted: December 09 2007 at 11:55 | IP Logged
oh, well that's, ummm, so obvious  8-}  (not!)
 seriously - thanks for the tip, ain't computers ergonomic?
 thanks Dave 8-}
  Edited by jeffw_00 - December 09 2007 at 11:55
           | Posted: December 09 2007 at 12:21 | IP Logged
 8-}
 /j |
 Ha!  Well, I'm a computer programmer and you're likely running some of my code now :}  ... but when it comes to HA and PH, I'm a noob.   Some of it translates easily, but some stuff not so easily!
           | Posted: December 09 2007 at 12:26 | IP Logged
Well, - I design chips for consumer products (used to design computers way back), so you may be using some of my stuff too 8-}
 on the other - Dave, as always, had the answer
           | Posted: December 09 2007 at 12:32 | IP Logged
Well that puts me out of the "Do Loop" I come from the Main Frames days. Ever heard of MVS, QTAM, BTAM and how about old DOS?
           | Posted: December 09 2007 at 12:37 | IP Logged
heard of MVS (I think), still use DOS
           | Posted: December 09 2007 at 12:48 | IP Logged
Nope.. different DOS. Before PCs all the way back to TOS (Tape Operating System) then DOS (Disk Operating System) and SVS (Single Virtual Storage) then MVS (Multiple Virtual Storage) and VM (Virtual Machine).
