tbeckman Senior Member
| Posted: October 10 2008 at 19:57 | IP Logged
I have reviewed examples on this forum and can seem to find one using the combination below... but I have tried this and it is not working for me... I am using the following boolean in a trigger to trigger if the time is after 10pm and before sunrise... can anyone take a look at what I am trying to do and see if my boolean format looks correct. Thank you.
if(NOW()> 22 AND NOW() < RELATIVETIME( 00:00:00, [SUNRISE] ), 1, 0)
jbbtex Senior Member
| Posted: October 10 2008 at 21:51 | IP Logged
For the first condtion try - HOUR(NOW())>22
__________________ Brady
JaredM Newbie
Online Status: Offline Posts: 36
| Posted: October 10 2008 at 21:54 | IP Logged
And you'll also want to make it >= 22 otherwise it won't fire until 11pm or later and change the AND to an OR.
if(HOUR(NOW())>= 22 OR NOW() < RELATIVETIME( 00:00:00, [SUNRISE] ), 1, 0)
| Posted: October 10 2008 at 22:00 | IP Logged
Like Brady you may also want to modify the NOW()> 22 to NOW() > 22:00:00
| Posted: October 11 2008 at 00:03 | IP Logged
I believe this covers the conditions you documented. After 22:00:00 and before Sunrise. There are some issues when comparing time with an IF. The time(“22”) function returns hh:mm:ss 22:00:00; the now() function returns hh:mm:ss:mmm (down to milliseconds’). I chose to put all times into hh:mm:ss format so the IF comparison would be comparing apples to apples. I have successfully run this statement with the Formula Builder. Also tested it across midnight. It returns 1 (true) from 22:00:00 + 1 second to SUNRISE - 1 second. It returns 0 (false) outside that time range.
The first part of the IF checks for the current time being between 22:00:00 and 23:59:59. If current time is outside that range the IF checks for the current time being before SUNRISE.
if((ph_relativetime(now(),0)>time("22") and ph_relativetime(now(),0)<=time("23:59:59")) or ph_relativetime(now(),0)< ph_relativetime(time("00"),long(ph_getsystemvar("SUNRISE"))) ,1,0)
EDIT:
The "and" part of the time check, <= 23:59:59, is not necessary and can be removed. Old habit of defensive programming. I'm sure someone would point that out eventually.
Tested published statement across sunrise, no surprises. Sunrise is 07:17:34 here. Returned 1 (true) until sunrise, at which point the IF started retuning 0 (false).
Edited by grif091 - October 11 2008 at 07:19
| Posted: October 12 2008 at 00:02 | IP Logged
Sorry folks, this is what happens when you don’t read carefully all the previous posts. The original post from tbeckman with JaredM changes is much simpler, easier to understand, and it works!
| Posted: October 12 2008 at 12:03 | IP Logged
Thank you all for your help... I applied the if statement to my boolean field statement and it works...THANK YOU. However, I don't really understand why I would use and OR instead of an AND. An AND seems to make more sense to me because I would want both statements to be TRUE. It would seem using and OR in this statement would make it TRUE all the time. Is it after 10 or before sunrise? Seems like this would always be TRUE. Why would I use an OR? Thank you.
| Posted: October 12 2008 at 12:44 | IP Logged
I don’t know how the OR would work.. If is was after 22:00 period the condition would be met or if it was before sunrise and before a 23:59 time period the condition would be met because of RelativeTime which means the 22:00 did not apply. Lee, you know more about this than I do, chime in..
| Posted: October 12 2008 at 13:08 | IP Logged
It has to do with how time is represented. At 10 PM the time is 22:00:00. The first part of the IF compare returns True for times from 10 PM to 11:59:59 PM (22:00:00 through 23:59:59). At midnight the time is 00:00:00, at 1 AM the time is 01:00:00, and so on. A time of 1 AM, 01:00:00, is not greater numerically than 10 PM, 22:00:00, therefore the first comparison is False, making the entire IF False when the conditions are ANDed together. All conditions of an AND must be True for the IF to return True. The second part of the IF, the OR condition, covers the times from midnight to SUNRISE. The IF is read, if the time is from 22:00:00 to 1 second before midnight, OR from midnight to SUNRISE, return True, otherwise False. Once the time passes SUNRISE, the IF returns False because both comparisons are False. When the time reaches 10 PM again, the first part of the IF is True, causing the IF to return True because the comparisons are ORed, Either comparison being True returns True.
JaredM Newbie
| Posted: October 12 2008 at 13:12 | IP Logged
Tbeckman, I had the same thought at first when I was messing with it. But is has to be OR.
if(HOUR(NOW())>= 22 OR NOW() < RELATIVETIME(00:00:00, [SUNRISE]), 1, 0)
The reason it's an OR is that both statements will never be true in the same day. In a given day -- in one 24hr period -- the time can't be both after 10pm (>22) and before 7am (<7) at the same time. NOW() resets to 0 every day, so this is why OR works and AND doesn't.
| Posted: October 12 2008 at 13:19 | IP Logged
I must be confused then. I thought RelativeTime was a 24 hour period before. From the Help menu:
relativetime PowerHome formula function
Description
Obtains a time that occurs a specified number of seconds after or before another time within a 24-hour period.
| Posted: October 12 2008 at 15:07 | IP Logged
Thank you for this explaination... this makes sense.
The reason it's an OR is that both statements will never be true in the same day. In a given day -- in one 24hr period -- the time can't be both after 10pm (>22) and before 7am (<7) at the same time. NOW() resets to 0 every day, so this is why OR works and AND doesn't. |
| Posted: October 12 2008 at 15:12 | IP Logged
To answer my own question I was confused. Pea brain finally got it worked out. Back to the beach.
