tbeckman Senior Member
| Posted: October 21 2008 at 23:17 | IP Logged
I am running V2 and just created a new macro that would trigger when a motion sensor turned on. The macro turn a light on and then wait a few minutes and turn it off. Nothing I did would get the light to turn on. The logs even showed a message sent to turn it on and ACKed that it was on. If I manually turned the light on while the macro was waiting... after waiting the macro WOULD turn it off. I did using INSTEON - ON and using FORMULA - ph_insteon("NAME", ion ,255). Neither would work no matter what I did.
I finally added the ph_insteon("NAME", ion ,255) to an action in the trigger and then made another trigger to turn on the wait macro with the command to turn off after a certain amount of time... this works. But I am baffled why the command would not work within the macro.
