           | Posted: December 15 2008 at 13:41 | IP Logged
I have my home cameras (webcamXP) set to detect motion
 and when seen, send a trigger to PowerHome so that I can
 then send an SMS message to my cell phone to alert me.
 But I can't get it to work.  I never get a message on my
 phone.
 The PH Log shows "email sent to "734604xxxx@txt.att.net"
 followed immediately with a second entry that says
 "email sent to" with no parameter.
 The trigger from webcamXP is successfully firing my
 action macro as I get the alert message on the PH
 screen, but no SMS message ever arrives at my phone.
 My command string used in the macro is . . .
  ph_sendemail("734604xxxx@txt.att.net","Motion",time)
 The 'time' entry is intended to post the time the motion
 was detected as the SMS message.  In case this parameter
 was the cause of the error, I changed that entry to
 "CAM2" but it made no difference.
 Can I do what I want with ph_sendemail or do I need to
 use the ph_sendsmtpemail function?  Also is my call of
 'time' proper or do I convert it's results into a text
 string to send as an SMS message?
           | Posted: December 15 2008 at 14:42 | IP Logged
I figured out why email was not getting sent.  I had not
 configured Outlook Express to ever do anything.  Once I
 set it up with my Yahoo email POP service,all works
 well.
 I can now get SMS messages.  The nice thing now is that
 (hopefully) I can next set up a command interface so I
 can turn this on/off when away.  Days I know there will
 be someone in the house to water plants, etc. I can
 disable the extraneous SMS messaging.
 The problem of how to display TIME still remains though.
 How can I present the time of the detected event as the
 SMS message?
           | Posted: December 15 2008 at 14:59 | IP Logged
I’m out of my expertise but shouldn’t time be a string? Maybe like “{global time}”
           | Posted: December 15 2008 at 15:11 | IP Logged
Yep BeachBum.  You are exactly right!
 I was just coming back onto the Forum to say, "I'm on a
 roll today.  I fixed the problem.
 That's the good news.  The bad news is that I'm almost
 as fast Smart as I am Stupid."  Unfortunately the latter
 is slightly exceeding the former today!
 The correct command entry is . . .
 ph_sendemail("734604xxxx@txt.att.net","HouseMotion",stri
 ng(now()))
