           | Posted: December 25 2008 at 13:56 | IP Logged
For those of you that use Vista, you probably already know it has some unique volume control "capabilities".
 PH has:
 ph_setsysvol()
 ph_getsysvol()
 ph_getsysvolmax()
 ph_getsysvolmin()
 But these appear to only set PowerHome's application volume, not the OVERALL volume of the computer.
 Ideally, I would like to be able to control PH's volume, other applications volume, AND the overall system volume.
 Has anyone else figured out a work around?
           | Posted: December 25 2008 at 14:06 | IP Logged
I use ph_setsysvol(20208) with Vista and it sets Vista volume to 50.
           | Posted: December 25 2008 at 19:20 | IP Logged
Yes, setting the volume is presently possible using the commands I mentioned, but is there anyway to set the OVERALL volume (and not just the application volume) when multiple applications are opened?
         nadler Super User
           | Posted: December 25 2008 at 19:50 | IP Logged
In XPsp2 those commands do control the overall PC system
 volume and not the application volume.  Not sure about
 Vista though.
           | Posted: December 25 2008 at 20:14 | IP Logged
Most of my apps have their own volume control but I don’t know of any way to have PH control them.
         theowl Groupie
 Online Status: Offline Posts: 59
           | Posted: April 22 2012 at 17:18 | IP Logged
I know this topic is years old, but here is how I just handled this on my Win 7 system.
 1. Downloaded nircmd from http://www.nirsoft.net/utils/nircmd.html
 2. Unzipped the files and placed them in c:\windows\
 3. Replaced ph_setsysvol() with the following:
 a. Set system var TEMP1 to the desired volume number (between 0 and 65000)
 b. ph_run('nircmd.exe setvolume 0 [TEMP1] [TEMP1]')
 Explanation: I'm telling the system to set the right and left channels of main volume (0) to whatever is in TEMP1. This seems to be working fine on a Win 7 32bit system.
 Hope that help someone, this conversion to Win 7 has been very interesting so far. Now I'm off to figure out why firecracker can't get a signal to the A/V center.
 Peace!
