kev21986 Senior Member
| Posted: May 12 2009 at 17:22 | IP Logged
Is there an eval function? I am basically looking for a way to pass a formula to PH through a psp page with ph_getwebparm. Is this possible?
@respectTheCode
| Posted: May 13 2009 at 07:36 | IP Logged
You want ph_formula() for your eval function.
| Posted: May 13 2009 at 09:15 | IP Logged
TonyNo wrote:
| You want ph_formula() for your eval function. |
Thanks. Ill try it tonight.
@respectTheCode
| Posted: May 14 2009 at 22:01 | IP Logged
Depending upon how I interpret your question, you may also want to look at the PH cgi function evalformula.
It takes two parameters, formula and nexturl, and allows you to submit a formula for evaluation to the PH webserver. A simple URL would look like this:
| http://127.0.0.1/ph-cgi/evalformula?formula=ph_macro("YOUR MACRO ID")&nexturl=YOURPSPPAGE.PSP |
| Posted: May 15 2009 at 06:42 | IP Logged
That is even better than what I was looking for.
evalformula isn't working for me, but formula is working great. One thing to note is that the formula needs to be URLEncoded. It looks like it will take a POST and that wouldn't.
Quick proof of concept
| http://10.1.10.2:8080/ph-cgi/formula?formula=ph_devicecontro l(%22INSTEON%2BMSTR_FAN%2BOFF%22) |
Edited by kev21986 - May 15 2009 at 06:43
@respectTheCode
| Posted: May 15 2009 at 06:49 | IP Logged
What about something like this
| http://10.0.10.2:8080/ph-cgi/formula?formula=ph_getinsteonle vel(%22MSTR_FAN%22) |
This returns a full html page with the result in the middle of it. Is there a way to get just the result?
@respectTheCode
| Posted: May 15 2009 at 11:15 | IP Logged
Kevin,
evalformula most likely worked (you can check the log), it just doesnt return the result to you. Its good to launch a macro or other command where you're not interested in the result and instead want to navigate to a particular page when done.
What you're looking for is /ph-cgi/eval. It takes a single parameter "formula". This will return the result only without any other data.
Also, look at the ph_htmlescape function for URLEncoding.
| Posted: May 15 2009 at 11:40 | IP Logged
that makes sense.
I will give that a try tonight.
@respectTheCode
