| Posted: March 23 2010 at 15:48 | IP Logged
You would think this would be simpler...
I have several Controllinc's and KPLs in the house. After a long period of trial/error, I finally wrote common PH code that would detect -either- the Broadcast message -or- the Cleanup message, but not both. This gives me very reliable operation because it's very very rare that both messages don't get detected. However, it's not at all rare that one message, or the other, isn't detected.
So I have code that, if it detects the broadcast, ignores the cleanup, or alternately, if the cleanup is the first thing it sees, it acts on it.
Still, I've always wondering if this is what SL intended, or whether there's a more straightforward way to most reliably detect a keypress (which seems pretty important).
any thoughts?
thanks
| Posted: March 23 2010 at 20:39 | IP Logged
The Group Broadcast is not retried so missing that one is possible but unusual. Missing the Group Cleanup Direct is so unusual to suggest that something is very wrong with powerline communication or the PLM as the KPL/Controlinc will resend the Group Cleanup Direct until the PLM ACKs it. There is a max 3 retry attempts but if a total of 5 commands do not work there is a very significant problem.
Edited by grif091 - March 23 2010 at 20:42
| Posted: March 23 2010 at 21:00 | IP Logged
missing the cleanup is rare, much more rare than missing the broadcast, but not unheard of in this house. I suppose I could go looking for the problem, but on the other hand, my "either-or" seems to be pretty darn rock solid.
I don't see the retry attempts you mention, and if I remember correctly, I don't think keypad presses are hand-shaked, which is why this issue occurs. How sure are you that the KPL looks for an ACK of the cleanup?
| Posted: March 23 2010 at 21:17 | IP Logged
You will not see the retry process in the PH log as that is all between the PLM as a Responder and the KPL/ControLinc as a Controller. My KPL buttons actually blink when the responder fails to ACK. There is a post on the Smarthome forum that indicates the newest KPL buttons no longer blink when doing retries. You can usually watch the retry activity with a PLC that is being monitored by some other piece of software. I keep hoping that Smartlabs will develop an independent powerline Insteon message monitor something like the Monterey Signal Analyzer for X10 but for now the only way I know of is to use one of the old PLCs. It is not absolute but better than nothing.
| Posted: March 23 2010 at 21:20 | IP Logged
my buttons blink when the controller is out to lunch as well, but even when they don't, I saw better reliability when I put the 'either or' in place.
MrGibbage Super User
| Posted: March 24 2010 at 15:04 | IP Logged
I also find detecting keypresses inconsistent. I have
rewritten the code for detecting my CL presses, that I
don't remember what I have tried and what I have not. I
would be interested in seeing your code, if you would be
willing to share.
Bottom line is I do not see the detection of keypresses
reliable at all. I think it is pretty important to all
this HA stuff, and I really wish it was more reliable.
| Posted: March 24 2010 at 15:21 | IP Logged
Another point I want to add to Lee's post is that the group cleanup command (the direct, ACKed command following the group broadcast) is not a guaranteed command and may never actually be sent. The Insteon protocol has the group broadcast sent when a button is pressed (unACKed and not retried) followed by the group cleanup command direct to each responder UNLESS another Insteon traffic takes place in which the group cleanup sequence is aborted. So if you've got other traffic occurring when you press a button, its likely you will ONLY get the group broadcast which is not as reliable as the group cleanups. Ive always thought this was a troublesome aspect of the protocol.
With that aside though, probably the best way to track a button press (unfortunately wont work until the beta is released) will be to add a Virtual Insteon device as a responder to the button and then setup an Insteon Device Chg trigger on the virtual device. This will allow you to have a single trigger to monitor the button press as well as allow you details into what was the actual command (broadcast/cleanup/etc) that caused the Device change.
| Posted: March 24 2010 at 15:54 | IP Logged
Dave's first paragraph jives with my memory. How they could make everything else so handshaked and leave out keypresses still astounds me.
Dave - as for your 2nd paragraph - Probably my lack of understanding, but I don't see how that helps. I already use a trigger on Insteon Device Chg to detect the keypress. All keypresses go to the same macro (with one LOCAL passed to differentiate which key was pressed), and the first thing the macro does is the XOR on the broadcast vs. cleanup msg before calling a macro to execute the desired command.
How does your Virtual device reduce my code? (I can wait for the Beta doc to learn the answer if you prefer).
I'll post my code tonight or tomorrow night.
| Posted: March 24 2010 at 17:07 | IP Logged
Jeff,
I must have misunderstood. I was thinking that you had a couple of triggers...one for the group broadcast and one for the group cleanup. If you're already using Device Chg then you're good and wouldnt need the Virtual Insteon device (you must already have a real physical device that you're using for the Insteon Device Chg).
The virtual Insteon would be good for those situations where you don't want to actually link a physical Insteon device (other than the PLC...got to do that in order for a message to be generated) to a secondary KPL button or similar and want to fire triggers off of the secondary key presses. An example of how I do this is to have secondary KPL buttons with no physical devices linked to fire triggers in PowerHome to remotely change my Russound whole house audio controllers music source. A completely un-insteon action all controlled via Insteon .
| Posted: March 24 2010 at 17:15 | IP Logged
Hi Dave - I don't have the code in front of me, but I found the most reliable approach was to trigger off any change, and then decode -which- change in the macro and act accordingly.
Maybe not worth responding, but I lost you - not sure what you mean by "secondary KPL buttons with no physical devices".
anyway - I guess with the hole in the protocol the XOR is the way to go - i'll post the code soon
| Posted: March 25 2010 at 11:41 | IP Logged
Is this virtual insteon switch in response to this:
http://www.power-home.com/forum/forum_posts.asp?TID=1276
If so, cool! :) I think that will solve the problem, and
will be a very powerful feature.
Dave, when you get a chance, can you post an
example/tutorial of how we will set it up, and then use
it? Maybe include a screenshot of any applicable
screens?
Skip
Edited by MrGibbage - March 25 2010 at 11:42
| Posted: March 25 2010 at 19:53 | IP Logged
Ok, my code is below. Basically it looks to see if it got a broadcast or a cleanup, if it gets a broadcast, it sets a global for about 1 second, and then executes the macro. If it gets a cleanup, it checks the global, and exits if the global is set, otherwise it executes the macro. I usually disable most of the user messages.
the CLEANUP counter (detects Broadcast without cleanup) currently reads 40, and I haven't cleared it in months.
HTH
KEYPRESS 1 COMMENT getvar_n(2,4) = 5 means broadcast, 6 means cleanup
KEYPRESS 2 GOTO LABEL if(ph_getvar_n(2,4)=5,"NE XTLINE","CHECK_FOR_CLEANUP")
KEYPRESS 3 USER MESSAGE "BROADCAST_DETECTED, KEYPAD: [LOCAL1] key: [LOCAL2]"
KEYPRESS 4 FORMULA ph_macroparm("DOBROADCAST",ph_ getvar_s(1,1),ph_getvar_s(1,2),0,0,0)
KEYPRESS 5 GOTO LABEL "START"
KEYPRESS 6 LABEL & nbsp; CHECK_FOR_CLEANUP
KEYPRESS 7 GOTO LABEL if(ph_getvar_n(2,4)=6,"NE XTLINE","DONE")
KEYPRESS 8 USER MESSAGE "BROADCAST = {BDCST}"
KEYPRESS 9 GOTO LABEL if ({BDCST}=1,"NEXTLINE","CLEANUP_START")
KEYPRESS 10 SET GLOBAL BDCST 0
KEYPRESS 11 FORMULA   ; ph_killmacrowait("DOBROADCAST")   ;
KEYPRESS 12 USER MESSAGE "CLEANUP DETECTED AFTER BROADCAST, KEYPAD: [LOCAL1] key: [LOCAL2], ABORTING"
KEYPRESS 13 GOTO LABEL "DONE"
KEYPRESS 14 LABEL & nbsp; CLEANUP_START
KEYPRESS 15 USER MESSAGE "CLEANUP DETECTED, KEYPAD: [LOCAL1] key: [LOCAL2]"
KEYPRESS 16 LABEL & nbsp; START
DOBROADCAST 1 FORMULA   ; ph_killmacrowait("DOBROADCAST" )
DOBROADCAST 2 SET GLOBAL BDCST 1
DOBROADCAST 3 WAIT 1
DOBROADCAST 4 JUMP &n bsp; if({BDCST}=0,999,1)
DOBROADCAST 5 SET GLOBAL BDCST 0
DOBROADCAST 6 SET GLOBAL CLEANUP ph_addtoglobal("CLEANUP",1)
DOBROADCAST 7 FORMULA ph_setvar_s(1,8,string(today() ,"yyyy-mm-dd hh:mm:ss.fff"))
DOBROADCAST 8 FORMULA ph_setvar_s(1,7,"[LOCAL8]: BROADCAST, BUT NO CLEANUP, RECEIVED. KEYPAD: [LOCAL1], key [LOCAL2] " + char(13) + char(10)) 0
DOBROADCAST 9 FORMULA   ; ph_writefile("c:\jeff\insteon\error.log",0,ph_getvar_s(1,7))
| Posted: March 25 2010 at 19:59 | IP Logged
ps - could someone remind me the right way to export a single macro? 8-}
| Posted: March 25 2010 at 23:02 | IP Logged
Using Powerhome Explorer, with the list of Marcos displayed in the right pane, right click on the macro you want to export. A list of functions is displayed with Export being one of them.
| Posted: March 26 2010 at 10:42 | IP Logged
thx
