k2zs Senior Member
| Posted: November 29 2011 at 05:10 | IP Logged
My Electrician is recommending switching to LED lights
due to the number of lamps in the home. We've had to
replace switches quite often due to the draw caused by
incandecent lights.
I guess these new LED lamps are the future replacement of
CFL's and only draw 10% of the energy. My question is:
-Has anyone had any experience using LED lights with
Insteon? Do they work?
-Are they going to generate any noise on the network that
may hamper Insteon communication?
Home Automation Ideas
Gadgets Senior Member
| Posted: November 29 2011 at 12:46 | IP Logged
I don't know about noise, but they may glow a little even
when off. There is a module recommended for LED use but it
is a outside appliance module. I don't know if there is
versions for indoor switches and plugs etc.
| Posted: November 29 2011 at 13:51 | IP Logged
Scott,
I have a few LED lights controlled by Insteon. They don't seem to introduce noise (that I can tell) and seem to work fairly well. The biggest problem I have is dimming even though I bought LED bulbs that are supposed to be dimmable. They do dim, but anything other than full brightness causes them to flicker or jump back and forth between the current dim setting and something dimmer. It does this back and forth, not continuously, but every 10 - 15 seconds so dimming is basically unworkable. Not sure if this is a function of the LED bulb itself or the Insteon 2476D switchlinc that is controlling it.
patrickm Senior Member
| Posted: November 29 2011 at 22:39 | IP Logged
I have a few Cree LED lights that are controlled by Insteon dimmers. They work very well through the dimming range. My only complaint is their cost (~$40 a lamp).
Patrick
BwiggleS Newbie
| Posted: December 01 2011 at 07:33 | IP Logged
I question your electrician. I understand the desire to replace the incandescent bulbs with energy efficient ones, but picking LED over CFL? Compare a 6W bulb from Philips web site of each technology.
LED Bulb, 6W, 2700k, 200 lumens, 45000 hours
CFL Bulb, 5W, 2700k, 215 lumens, 8000 hours
CFL bulbs are more energy efficient than LED. CFL bulb costs around $4 while LED costs $28, seven times more.
7 CFL bulbs at 8000 hours is 56000 hours of run time for the same cost.
If a bulb averages 4 hours on a day, thats 1400 hours a year so a CFL should last 5.5 years while LED 32 years.
Also, CFL are available for many different configurations while LED are just coming out. I have a couple LED bulbs because I just wanted to try them. They seem to work fine but are not on my insteon devices. But I won't buy any more until the price becomes more reasonable.
Brad
| Posted: December 01 2011 at 14:39 | IP Logged
I have changed to LED recessed and ceiling fixture lights
almost all over the house. Because I only dim the
recessed lights a little, they have worked fine with
Insteon.
The light bulb replacement LEDs on the ceiling fixtures
that I like to dim to 15% for night lites did not work.
It is almost impossible to dim a pure LED that far
because they are DC devices and on an AC power line they
need to have rectified DC which usually has a capacitor
to smooth out the rippling voltage waveform, and the
small voltage pulse from an Insteon triac dimmer circuit
is enough to significantly charge the capacitor and light
the very efficient LED considerably brighter than the
target 15%.
I have made everything work perfectly, however, in a two
bulb fixture by putting a 15W tiny incandescent bulb in
one socket and the LED bulb in the other. The
incandescent bulb helps to absorb the short Insteon
voltage pulse and "use it up" so the LED doesn't act like
a white-dwarf star all by itself!
Edited by GadgetGuy - December 02 2011 at 07:47
k2zs Senior Member
| Posted: December 02 2011 at 07:33 | IP Logged
Thanks to all for the great feedback...
