         nerdboytodd Newbie
 Online Status: Offline Posts: 11
           | Posted: January 06 2012 at 17:43 | IP Logged
Just today I started noticing that my PH box wasn't responding to events from my Elk M1 Gold, so I took a look at the log and found this message:
 "System Message      The Elk M1 ELKM1GOLD Zone Status Request did not return properly. Commands will not be transmitted."
 I have had this setup working (with the Elk M1 Gold connecting via Ethernet to the PH over the unsecure port (2101)) for around a year now with no issues. I've rebooted the PH system, I rebooted the Elk XEP, I rebooted the M1 Gold itself. To no avail. I didn't change anything today, so no reason why it should stop communicating now.
 Any thoughts? A few forum searches have turned up very little (I've checked to ensure the unsecure port on the M1Gold is turned on.
 TIA,
 NerdboyTodd
           | Posted: January 07 2012 at 15:44 | IP Logged
Todd,
 I took a look at the source code and the Zone Status
 Request is the first function PowerHome performs during
 its connect phase after the socket is successfully
 connecting.  So it looks as if the connection to port
 2101 is happening ok, PowerHome sends the zone status
 request, and the data is either not being returned within
 the time allowed or the returned data is not properly
 formatted.
 Have you tried connecting to the Elk via the Elk RP
 program and verified the system has no problems?
 Assuming nothing has changed on the PC side and there
 isnt any firewall or similar software blocking 2101, it
 would appear to be something hardware wise with the Elk.
 Once you with ElkRP, can you give me the firmware version
 loaded in both your Elk-M1 and the XEP?  I can try to
 load the same version in my system and see if perhaps
 something is different there.
 Let me know,
         nerdboytodd Newbie
           | Posted: January 09 2012 at 11:18 | IP Logged
Thanks for the reply back, Dave.  I have checked both from the PH side and the Elk side.  I have accessed the Elk M1 Gold with my ElkRP software (v2.0.6) with no issues.  I also used my ElkRMS remote access software to access the M1 via the XEP and had no problem accessing those resources, so it looks like the XEP is at least mostly functional.  Again it's strange as there were no changes made to firmware/software on either side of this equation.
 The Elk M1 Gold Boot Ver is 3.3.6 and Firmware Ver is 5.2.2.
 The M1XEP Boot Ver is 1.2.0 and Firmware Ver is 1.3.10.
 Thanks for your efforts in helping troubleshoot this!  Love your work!
 NerdboyTodd
  Edited by nerdboytodd - January 09 2012 at 11:18
         nerdboytodd Newbie
           | Posted: January 09 2012 at 15:46 | IP Logged
Update:
 After posting the current revs of code I was running on the Elk M1 Gold. I went out to their site to see what the latest and greatest was.  So in an effort to make sure I was at the latest and greatest I updated the M1 Gold to Firmware Ver 5.2.8 and the M1XEP to Firmware Ver 1.3.28.
 The net result was no change on the error message I was getting from the PH system.
 On a lark, I was in the PH setup screen and listed my two controllers...the Insteon controller and the Elk controller.  The Insteon being listed first (10) and the Elk 2nd (20).  I decided to change the order by reducing the Elk to (5).  Reinitialized and damn if that didn't work.  Any idea why this would stop working and then why making this change would fix it?
 NerdboyTodd
           | Posted: January 09 2012 at 21:37 | IP Logged
Todd,
 Actually does make sense.  I remember this happening to
 someone else (may not have been Elk and Insteon but
 another case where controller load order was an issue)
 either on the board or through email.
 What I suspect is happening is that the Elk is getting
 timed out by an operation taking to long during Insteon
 initialization.  Insteon launches first, starts a timed
 process, gives up control, the Elk launches, starts a
 timed process, gives up control back to Insteon which
 then starts a process that takes longer than it used to
 and doesnt return control back to the Elk in a timely
 fashion.  After control is returned, the Elk process has
 timed out and you get the error message.  Changing the
 order just switches the order of the processes and its
 not an issue any more.
 Probably some slight change in your Insteon network (new
 devices, etc.) or possibly some communication issues (a
 new computer power supply causing noise, etc.) and the
 Insteon init process is taking a little longer than it
 used to and the error started showing up.
 Glad you happened upon this because I doubt I would have
 thought to try that  .
