         cox181 Newbie
 Online Status: Offline Posts: 12
           | Posted: February 02 2012 at 06:04 | IP Logged
After I tick the box "load script server" under
 Maintenance, Powerhome explorer, setup, preferences. Then
 I reinit and get the script server error. I originally
 though this was only an error for windows 7 x64 bit
 users, but I just installed XP on a different computer
 and still get the same script server error. I first
 installed 2.1.2 and then unzipped 2.1.4 over the
 powerhome directory which is C:\powerhome
 So what is the fix for this? Is no one else running into
 this problem? Not being able to run external scripts is
 very frustrating because there are a lot of applications
 for controlling things with scripts. So any help would be
 appreciated.
         ivulpe Newbie
           | Posted: February 02 2012 at 12:47 | IP Logged
I had the same problem. I think you need to manually register the new script server with the command: regsvr32 "c:\powerhome\ph_scriptserver.ocx".
  __________________ I
           | Posted: February 02 2012 at 15:09 | IP Logged
Taylor,
 Ivulpe has you covered.  Running the regsvr32 command should eliminate the error.
         cox181 Newbie
           | Posted: February 02 2012 at 15:13 | IP Logged
so we just type that command into the Macro/Formula box and
 then hit run?
           | Posted: February 02 2012 at 22:13 | IP Logged
Taylor,
 No,no...do this command from a command prompt.  On Win7/64 you can do Start->Run and type it there or type cmd.exe in Start->Search and run it from the command prompt.
