           | Posted: July 29 2018 at 09:15 | IP Logged
i've tried various formulas and they all syntax-error out.  I would think this would work
 ph_setglobal_s("NEW",ph_getglobal_s("ORIG"))
 but I get a syntax error.
 what's the right way to do it?
           | Posted: July 29 2018 at 16:38 | IP Logged
Jeff,
 That is definitely the right way to do it so not sure what would be going on. I just tested out on my system and the below worked without
 issue:
 Which looks to me to be identical to what you have. The only thing I can think of is perhaps one of the globals doesnt already exist?  Nope,
 that wouldnt be it either as I just tested one and both of the variables not existing and I don't get a syntax error.
 A syntax error should be just that. Mismatched parenthesis', mismatched quotes, wrong number or type of arguments, etc.  I even copy/pasted the
 formula from your post and it executed just fine for me.
 Can you post or email me a screenshot of the formula and the error you're getting? Also a copy of what is currently in the "ORIG" variable.
           | Posted: July 29 2018 at 18:48 | IP Logged
Sorry - I had a typo in the post.  In my code the first was a ph_setglobal_a - which i guess is wrong, though I'm surprised it generates a syntax error.  Using setglobal_s (like in my post) works fine.
