         Francorosso Newbie
 Online Status: Offline Posts: 7
           | Posted: October 11 2018 at 11:18 | IP Logged
Here's the situation: In my basement I have 3 Insteon
 Switchlinc dimmers in different places, all to control
 the overhead lights.  Only switch A is actually
 connected to the load, switches B and C are connected to
 line power.  I have set switches B and C as CONTROLLERS
 of switch A.
 The question is whether switches B and C should also be
 RESPONDERS to switch A.  I didn't think so but somehow
 when I imported my links from Houselinc they show up as
 responders as well as controllers.
  __________________ Frank
           | Posted: October 11 2018 at 18:56 | IP Logged
I'd say no since B and C are not controlling anything.
         Frank-H Newbie
           | Posted: October 22 2018 at 14:46 | IP Logged
If all three switches are to control one light and
 switches B and C are not also responders to switch A:
 1. they will not reflect when you turn on the light
 using switch A.
 2. to turn off the light using a different switch than
 A (the one you used to turn it on), you will have to
 hit off on that switch twice, once to sync it to
 switch A and once to actually tell A to turn it off.
 When you make them responders to A it will be switch A
 that tells them to also show the light is on (in the
 leds on the switch) when A does turn it on. Being
 responders to A keeps them each in sync with A.
 BTW - They also should be responders to each other to
 keep them in sync with each other. Then it doesn't
 matter which switch tells A to turn on the light, any
 of the switches will accurately tell A to turn off and
 the leds on all three switches will all be in sync
 with the actual state of the light.
 Needless to say, because it is directly connected to
 the light, switch A's leds are always in sync with the
 light.
  __________________ The Blind Squirrel-
 Even I find a nut once in a while.
           | Posted: October 22 2018 at 15:10 | IP Logged
Nicely stated Frank-H.
 Welcome to the group!
