        | niels Newbie
          When I run my nightly backup on the machine that runs PowerHome, do I need to shut it down prior to the backup in order to ensure that the backed-up database file is in a consistent state?
           | Posted: September 29 2007 at 23:37 | IP Logged |   |
 Even better, is there an easy way to make PH do a dump of its entire DB which I can safely backup, then later import like I do with Oracle and MySQL?
 Niels.
        | niels Newbie
          Looks like ph_backupdb is what I need.
           | Posted: September 30 2007 at 00:01 | IP Logged |   |
        | ginigma Senior Member
          Yep.  My actual command is as follows:
           | Posted: September 30 2007 at 23:17 | IP Logged |   |
 ph_backupdb ("C:\HA\PowerHome\Database\Backups\phdbbackup." + string (year (today ())) + string (month (today()), "00") + string (day (today()), "00") + ".db", 0)
 I run it daily overnight and that gives each file a unique name.
 Insteon (40 devices) ^ PowerHome (435 links) ^ Logitech Harmony 880
        | Back to Top |       |
