        | dhoward Admin Group
          All,
           | Posted: July 15 2008 at 23:55 | IP Logged |   |
 Just wanted to give everybody an update on the next PowerHome beta.  We're real close, I should have it ready for download in the next 2 weeks.  Some of the features I promised for this next beta are having to slip due to time constraints (they'll be at the top of the list for the next beta).  However, we do have alot of new features including:
 UPB support including triggers and import from UPStart.
 Finished support for the Insteon PLM.
 Enhanced Timed Events including ID, Active, and Boolean fields.
 Enhanced Control Center functionality setting the stage for new CC objects.  Some of which may make it into this beta
  . The ability to copy a group of CC objects from 1 tab to another.
 The ability to resize a group of CC objects based upon a percentage.
 The ability to filter the Device Status screen by location dropdown.
 The much requested auto-shutdown of the SDM when PowerHome exits.
 Enhancements to Elk M1 Gold support.
 Numerous bug fixes and Insteon updates.
 Upcoming features planned are:
 Z-wave support
 ISY support
 Insteon NetLinc support
 Global Cache IRE and IRL support
 Just wanted to give everyone a quick update on status
 Oops...almost forgot.  One of the big features of the next beta will include an updated manual.  The current manual is way out of date and I know this will be a welcome addition.
 Another oops...the next beta will also include the first cut at a new Setup wizard that will also pre-generate Control Center screens based upon your defined devices.
 Edited by dhoward - July 16 2008 at 08:51
        | Back to Top |       |
        | jeffw_00 Super User
          Great news Dave - thanks for the awesome effort.
           | Posted: July 18 2008 at 10:16 | IP Logged |   |
 Will it support the Insteon Motion Sensor?
        | Ktulu Newbie
          This is indeed good news. I'm really looking forward to the updated documentation. I've also been patiently waiting for Insteon thermostat support. I'd like to see what PH can do with that device before I purchase one.
           | Posted: July 18 2008 at 11:20 | IP Logged |   |
 Jeff
 "Assiduus usus uni rei deditus et ingenium et artem saepe vincit" - Cicero
        | nadler Super User
          Jeff,
           | Posted: July 18 2008 at 11:54 | IP Logged |   |
 |  Just so you know, PowerHome already supports the Insteon Thermostat.  I'm running two right now. See this thread:
 http://power-home.com/forum/forum_posts.asp?TID=1683&KW=Inst eon+Thermostat&PN=0&TPN=2
 On Page 3 there is a macro you can import from Martlist which sets up everything for you.  Takes a couple of minutes.
 BTW, I bought my second Thermo off ebay for $42(the 7 day programmable version) and bought the Insteon Adaptor from smarthome when they were having a sale.
 You certainly don't need the 7 day version if you are going to use PH but the 7 day version supports the humidity sensor which the 1 day version does not.
 From PowerHome you can remotely control the thermostat - raise and lower the temp and turn on the fan, heat, ac etc as well as check the Temp and Humidity at the stat.  I actually like it a lot.
 If you have any specific questions about it and PH let me know.
        | cmhardwick Senior Member
          Nadler,
           | Posted: July 20 2008 at 10:30 | IP Logged |   |
 I think Jeff's speaking of NATIVE support, without that work-around (which I use as well
 What command do you use for the fan? I missed that one!
 Cicero, Enjoying automation!
        | Back to Top |       |
        | jeffw_00 Super User
          i was referring to the recently announced motion sensor, not the thermostat ctl 8-}
           | Posted: July 20 2008 at 10:47 | IP Logged |   |
 |  /j
        | nadler Super User
          Fan On ph_insteon("THERMOSTAT",107,7)
           | Posted: July 20 2008 at 12:03 | IP Logged |   |
 |  Fan Off ph_insteon("THERMOSTAT",107,8)
 Jeff - I think the motion sensor will work with PH out of the box.
        | BeachBum Super User
          I think the real question that Jeff W is referring to is will the Insteon Types be defined for the Insteon Motion Sensor. And I agree with Noel it should work out of the box.
           | Posted: July 20 2008 at 23:49 | IP Logged |   |
 Pete - X10 Oldie
        | Ktulu Newbie
           | Posted: July 21 2008 at 10:08 | IP Logged |   |
| nadler wrote:
       | Jeff, Just so you know, PowerHome already supports the Insteon Thermostat.  I'm running two right now. See this thread:
 Thanks Nadler. If this next version supports the thermostat "natively," then there's really no reason for me not to wait.
 I actually went and checked up on that thread after posting here the other day and it's gotten further along than I anticipated. It seems you guys have it doing everything that I want it to do.
 While I'm waiting for this new release I need to educate myself on HVAC a little so I can hook the new 'stat up when I get one. So I've got a little homework to do anyway.
 Jeff
          Thanks Nadler, missed that part. Now to update my setup hehehe (like that EVER stops!)
           | Posted: July 21 2008 at 15:59 | IP Logged |   |
        | Back to Top |       |
        | jeffw_00 Super User
          not sure anyone really answered my qn.
           | Posted: July 23 2008 at 12:57 | IP Logged |   |
 I pre-ordered the Motion Sensor but if it won't work with PH (i.e., I won't receive hand-shook events from it), I should cancel the order...
 thanks!
 Edited by jeffw_00 - July 23 2008 at 12:58
        | JaredM Newbie
          I'm sure it'll be fine. By definition the thing must be able to send Insteon commands to other devices, which is enough for PH to be able to participate.
           | Posted: July 23 2008 at 23:49 | IP Logged |   |
 The question is not whether it will work but how easy it will be to get it hooked up in PH.
        | krommetje Super User
          Dave: Nice work, I am curious to see the new version...
           | Posted: July 24 2008 at 00:49 | IP Logged |   |
 note: Hopefully you can get started with the implementation with Zwave soon!
| Quote:
 this is fun!! now we can set a Timed Event, e.g. of every 5 min.,  with conditions
 e.g. if the temperature of [SENSOR1] > 80 then .....
 Peter
 Edited by krommetje - July 24 2008 at 00:58
        | Back to Top |       |
        | mustangcoupe Super User
          ok, enough for the teaser.... whats the status... :)
           | Posted: August 03 2008 at 20:55 | IP Logged |   |
 Todd Hannemann
 HA newbie
  PowerHome - UPB - ELK   |
        | Back to Top |       |
          double bump.... any updates?
           | Posted: August 17 2008 at 09:03 | IP Logged |   |
 Todd Hannemann
 HA newbie
        | Back to Top |       |
        | TonyNo Moderator Group
          Place your bets! My money is on 8/31.
           | Posted: August 17 2008 at 13:45 | IP Logged |   |
        | Back to Top |       |
          it's a date to shoot for... :)
           | Posted: August 18 2008 at 18:41 | IP Logged |   |
 Todd Hannemann
 HA newbie
        | Back to Top |       |
        | GadgetGuy Super User
           | Posted: August 20 2008 at 13:19 | IP Logged |   |
| nadler wrote:
       | ... I'm running two (Thermostats) right now .... From PowerHome you can remotely control the thermostat - raise and lower the temp and turn on the fan, heat, ac etc as well as check the Temp and Humidity at the stat.  I actually like it a lot...
 Nadler - I've been running my STAT now for several weeks and am having a lot of problems with it.  There are a lot of '03' events and until I placed an Insteon Access Point 3 feet away from the STAT I was getting so many NAKS from it, that PH shut the STAT off within minutes due to "Failed" comm attempts.
 Even now I seem to get a lot of false readings (ie, house temp at 9 degrees when it should be 73!)and I note in the Event Log that instead of responding with its correct address of 0E.60.36 I see a lot of 03.60.36 responses (I have no such device and the STAT is the only unit that comes close to matching that bogus address).  I'm a bit surprised that such errors can sneak by the CRC check on the message.
 What has your experience been?
 PS - I'm running the latest Alpha version of PH, if it makes any difference.
 Ken B - Live every day like it's your last.  Eventually, you'll get it right!
           | Posted: August 20 2008 at 13:23 | IP Logged |   |
| dhoward wrote:
       | Just wanted to give everybody an update on the next PowerHome beta.  We're real close, I should have it ready for download in the next 2 weeks.  Some of the features I promised for this next beta are having to slip due to time constraints (they'll be at the top of the list for the next beta).  However, we do have alot of new features... Dave.
 Dave - the new features list does not include the Insteon Thermostat.  Does it look like it will be included, and do you have a current time target for the beta release yet?
        | raven77 Groupie
          How about an Iphone app?
           | Posted: August 20 2008 at 15:21 | IP Logged |   |
   I know it would be easy enough for us to make our own webapp, but PowerHome would be a great addition to the app store!!!
