edtude Groupie
| Posted: July 10 2009 at 18:45 | IP Logged
Ok I have set up a Trigger for PH to send me a text message when the Motion Sensors batteries are low. So I have validated the whole ph_sendemail portion of the raw formula my question is just o validate my other thoughts...
Trigger Type: Insteon Group In
Trigger ID: Office Motion (The Motion Sensor)
Trigger ID Number: 3 for Group 3
Trigger Value On (0x11)
The Trigger ID is what I am unsure of...
| Posted: July 10 2009 at 20:20 | IP Logged
I think you are questioning the Trigger ID Number which should be 3 for Group 3 which is the Group number the Motion Sensor uses for low battery. If you are asking about Trigger ID, it is the ID you assigned to the Motion Sensor device entry. You can check the trigger by changing the Group Number to 1 and your activity should happen each time Motion is detected.
Edited by grif091 - July 10 2009 at 20:22
edtude Groupie
| Posted: July 10 2009 at 21:12 | IP Logged
Yes you are correct I was questioning the Trigger ID Number. So that is good I should get a text message when the low battery situation occurs. Thanks
