        | Brandon Newbie
          Hello!
           | Posted: December 29 2009 at 16:33 | IP Logged |   |
 I am new to the PowerHome community (just discovered application last night) and am very excited.  It seems I have found exactly what I was looking for.
 I have purchased (2) Neurosky Mindset EEGs along with the Insteon PowerLinc Modem (PLM-Serial) and am interested in utilizing the brainwave activity from the EEGs to control (3) LampLinc 2456D3 modules
 I am not a programmer (environmental engineer) but will be getting some help from a friend of mine who is comfortable with SQL, Ruby, and C.
 I have installed the trial of PowerHome and have setup the PLM and the 3 LampLincs and have begun to work through the PowerHome User Manual.
 Below is a workflow schematic of the project.
 I look forward to getting acquainted with Powerhome and the forum community.  I'd appreciate any links to forums or tutorials that I should be checking out.
 Brandon
        | Brandon Newbie
          Help with Parsing a Global Variable into Multiple Global Variables
           | Posted: January 02 2010 at 16:07 | IP Logged |   |
 I setup the Socket Server Command Line Application and have passed mock EEG data to GLOBAL Variable = SOCKETSERVER
 Structure of Global Variable SOCKETSERVER string
 "EEG1ADDR: 69.10.10; EEG1MED: 090; EEG1ATT: 075; EEG2ADDR: 10.11.12; EEG2MED: 030; EEG2ATT: 040"
 I would now like to parse the content of SOCKETSERVER into multiple global variables.
 I tried to do it by using a Macro with the Set Global command formula being mid(SOCKETSERVER, 11 {,8}) for EEG1ADDR and received an error.
 Brandon
        | BeachBum Super User
          Try this: mid("SOCKETSERVER", 11 ,8)
           | Posted: January 02 2010 at 16:42 | IP Logged |   |
 Don’t know if that is really what your after. Socketserver is a string therefore needs quotes. 8 is optional.
 Pete - X10 Oldie
        | Brandon Newbie
           | Posted: January 02 2010 at 17:18 | IP Logged |   |
 I tried your suggestion and it returns "ER" from the text "SOCKETSERVER".  What I am trying to do is return text from the variable.
 What was returned: ER
 What I am trying to get out: 69.10.10
        | BeachBum Super User
          I use something like this:
           | Posted: January 02 2010 at 18:44 | IP Logged |   |
 ph_setvar_a(3,27, posw(ph_getvar_s(3,21),"$$",ph_getvar_n(3,26)))
 And then I do a mid to get the date into a global:
 mid(ph_getvar_s(3,21), ph_getvar_n(3,26), ph_getvar_n(3,27) - ph_getvar_n(3,26) )
 Pete - X10 Oldie
        | dhoward Admin Group
          For the sample global you've posted above, you can use this:
           | Posted: January 02 2010 at 19:20 | IP Logged |   |
| Code:
       | ph_regexdiff1(": ",";",ph_getglobal_s("SOCKETSERVER"),1,4,0,0,0) |  |  |
 This will extract out a single value from the string.  In the code above, it extracts the 4th value.  To change the code to extract out the first, second, third, etc. value, just change the "4" to be the instance you wish to extract.  You can then use the Macro command "Set Global" to assign the extracted value to the global of your choice.
        | Back to Top |       |
        | Brandon Newbie
           | Posted: January 02 2010 at 23:30 | IP Logged |   |
| dhoward wrote:
       | You can then use the Macro command "Set Global" to assign the extracted value to the global of your choice. |  |  |
 How do I structure the Send Keys / TTS / Dim / Formula area for the Get Global command?
 I am a little confused about how formula results are then accessible as variables.  Is the result of the ph_regexdiff1 formula always stored in a specific location?
 Brandon
        | dhoward Admin Group
          Brandon,
           | Posted: January 03 2010 at 00:09 | IP Logged |   |
 The macro line would look like this:
 10 Set Global EEG1ADDR ph_regexdiff1(": ",";",ph_getglobal_s("SOCKETSERVER"),1,4,0,0,0)
 *Most* of the macro commands with the Send Keys/TTS/Dim/Formula field not grayed out are expecting a formula.  A formula can be as simple as the number 1.  You could also make the formula a string (strings must be enclosed in double or single quotes).  So the following are all formulas:
 1
 "Test1"
 'Test2'
 5 * 2
 "Test1" + ' ' + "Test2"
 "The result of 5 * 2 is " + string(5 * 2)
 A formula can result in either a string, a number, a date, a time, or a datetime.  The key is that you cannot mix terms (string and number) without casting one or the other like I did with the result of 5 * 2 in the last formula.
 The output of the ph_regexdiff1 formula is a string, the result of which will be assigned to the global.  To validate your formulas, just right-click the field and select "Check Formula" to make sure that there are no errors.
        | Back to Top |       |
        | Brandon Newbie
           | Posted: January 06 2010 at 18:38 | IP Logged |   |
| dhoward Hope this helps,
 [/QUOTE wrote:
 Yes, it did!  Thanks
 Brandon
 Yes, it did!  Thanks
 Brandon
        | Brandon Newbie
          I'm having trouble with the Insteon On command
           | Posted: January 18 2010 at 17:58 | IP Logged |   |
 I'm trying to pass a global variable as the control for cmd2 of an Insteon On command for a lamplinc
 When I do an integer("MINDSET1-ATT") it is evaluated to a 0 yet MINDSET1-ATT is set to 150.
        | grif091 Super User
          Try   ph_getglobal_n("MINDSET1-ATT")   This worked in an Insteon command test here.
           | Posted: January 18 2010 at 18:08 | IP Logged |   |
 Edited by grif091 - January 18 2010 at 18:11
 Lee G
        | Brandon Newbie
          sweet!  thanks grif
           | Posted: January 18 2010 at 18:10 | IP Logged |   |
        | Brandon Newbie
          Another Question::
           | Posted: January 18 2010 at 18:44 | IP Logged |   |
 Massaging Data in a Global Variable.
 I am using ph_readfile to copy the EEG output (.txt file) into PowerHome and assign as a global variable.
 Structure of EEG Output file (.txt):
 Global Variable - MINDSET1-OUTPUT
 Att: 40; Med: 51;
 Att: 53; Med: 56;
 Att: 53; Med: 61;
 Att: 43; Med: 66;
 Att: 44; Med: 77;
 Att: 27; Med: 63;
 Is there a way where I can lookup MINDSET1-OUTPUT and copy only the last line into a new global variable?
        | dhoward Admin Group
           | Posted: January 18 2010 at 19:11 | IP Logged |   |
| Code:
       | ph_setglobal_s("NEW-GLOBAL",mid(ph_getglobal_s("MINDSET1-OUT PUT",lastpos(ph_getglobal_s("MINDSET1-OUTPUT"),"~r~n")  + 2)) |  |  |
 Didnt actually verify but the above should work.
        | Back to Top |       |
        | Brandon Newbie
           | Posted: January 18 2010 at 22:49 | IP Logged |   |
| dhoward wrote:
| Code:
 Dave:
 couldn't get the code above to work.  will play around with some.
        | grif091 Super User
          These statements work here.  I used MINDSET1-DATA Global variable for the last line of data in MINDSET1-OUTPUT which was read from a file eegdata.txt.
           | Posted: January 19 2010 at 04:21 | IP Logged |   |
 ph_setglobal_s("MINDSET1-OUTPUT", ph_readfile("c:\temp\eegdata.txt"))
 ph_setglobal_s("MINDSET1-DATA",mid(ph_getglobal_s("MINDSET1- OUTPUT"),lastpos(ph_getglobal_s("MINDSET1-OUTPUT"),"~r~n")  + 2))
 Note that the forum post is adding a blank in the MINDSET1-OUTPUT string that has to be removed once put into a macro.
 This assumes there is no cr/nl after the last data line.  If there is a cr/nl on the last line then change the + 2 to - 17.
 Edited by grif091 - January 19 2010 at 11:21
 Lee G
        | Brandon Newbie
           | Posted: January 19 2010 at 14:10 | IP Logged |   |
 Thanks grif!  I'll try it out when I get home.
 I am happy to report that I was able to use my EEG to control 2 LampLincs last night.  One light was controlled by my attention level and one by my meditation level.
 Question:
 I want to keep looping my macro that handles the .txt file with the EEG data as long as new data is being added to the file.
 Is there a way where I can look at a file, and if the last line is a certain text ["Process has ended"] it will stop the loop?
 End Question:
 I am also happy to report that I am now a registered user of PowerHome.
 Bt
        | grif091 Super User
          Congratulations on joining Powerhome.
           | Posted: January 19 2010 at 15:10 | IP Logged |   |
 The statement I posted is Dave's suggestion with the addition of a right paren on the end of one of the imbedded ph_xxx commands.
 There are Macro   Label XXXXX  and Goto statements that allow looping within a Macro.  Something like
 Goto   if (ph_getglobal_s("MINDSET1-DATA") <> "Process has ended", "XXXXX", "Done")
 This has the effect of comparing the last line from the file to "Process has ended", if not equal the Goto goes to Label "XXXXX" which would be coded at the beginning of the Macro.  Otherwise, the Goto goes to Label "Done" which is not defined so the next sequential Macro statement is executed, probably the end of the Macro.
 The problem with this approach is the Macro constantly runs until it finds the "Process has ended" line in the file.  The PC will be running in basically a process bound loop which is not good.
 How do you invoke the Macro now?  Ideally the Macro should run only when something new has been written to the file.
 Lee G
        | Brandon Newbie
           | Posted: January 20 2010 at 17:55 | IP Logged |   |
 I hear what you are saying.  I am going to install the PowerHome File Monitor plugin to work with.
 Brandon
        | Brandon Newbie
          Using PowerHome and the File Monitor plugin my project of controlling lights via EEG brainwave activity is off to a good start.
           | Posted: January 21 2010 at 15:01 | IP Logged |   |
 I was able to control 2 lamps last night via the brainwave activity of 1 EEG.  One lamp was controlled by my Attention value and the other was controlled by my Meditation value.
 Cool stuff!  Thanks guys.
