jonkjon Groupie
Online Status: Offline Posts: 77
| Posted: June 21 2010 at 19:40 | IP Logged
If i set the web server up to use a port other than 80, and i click on the web center menu item from within PH, i get a server error as that menu item seems to be trying to access port 80 still. I know i am missing something......
| Posted: June 21 2010 at 23:21 | IP Logged
Should work. Did you reinit PH after changing the port?
jonkjon Groupie
| Posted: June 22 2010 at 12:48 | IP Logged
Yes, I did reinit.
| Posted: June 22 2010 at 14:11 | IP Logged
Which version of PH? Current?
jonkjon Groupie
| Posted: June 22 2010 at 18:41 | IP Logged
Yes......2.1b. The web page loads fine if i enter the port manually in a web browser. It is only a problem from within PH when I click the web center link in the control menu. Thanks for your help.
| Posted: June 23 2010 at 07:53 | IP Logged
Hmm. I run a non-standard port, too. It all works fine.
| Posted: June 23 2010 at 09:06 | IP Logged
Go into your pwrhome.ini settings fils and add your non-standard port to your path. See example below:
The ":90" is the port I am using. Do a re-init, and you should be good to go.
[Web Center]
home=http://127.0.0.1:90/ph-cgi/main
state=2
x=402
y=1220
width=4046
height=2044
jonkjon Groupie
| Posted: June 23 2010 at 10:01 | IP Logged
example below:
[Web Center]
state=2
x=402
y=1220
width=4046
height=2044
Thanks, that did the trick....I thought I had done that
already but it was the "WebServer" section that I
changed!
| Posted: June 23 2010 at 14:29 | IP Logged
Holy cow. That seems like a design flaw. Dave?
